Instrument lights not working
Mar 18, 2012 | 07:59 PM
I've replace the 4 main wiring harnesses and don't have any insturment lights. Everything else appears to be working fine. What have I forgotten?
Mar 18, 2012 | 09:14 PM
Mar 18, 2012 | 09:34 PM
Make sure everything is grounded good. You can run an external ground from the battery to check this.
good Luck.
Mar 18, 2012 | 09:50 PM
Mar 19, 2012 | 01:16 PM
Cruise-In II Veteran
Turn the headlight switch ****.
Mar 19, 2012 | 01:21 PM
Quote:
Originally Posted by
Easy Mike
Mar 19, 2012 | 02:15 PM
petes74ttop
Sometimes the obvious has to be mentioned. I have no shame, so it's no big deal for me to mention it.
Mar 19, 2012 | 05:19 PM
Did you remove the headlight switch there's a ground bar from H/L switch to speedo housing have seen them fall off.
Mark
Mar 20, 2012 | 10:10 PM
Come on Mike, that stung. But I'll try that next
Mar 20, 2012 | 10:14 PM
Thanks everyone for your replies. First I'll try the ground from the battery. I have to guess I forgot a ground on the back of both the center bezel and main dash. Darn it.
Mar 21, 2012 | 04:41 AM
I think someone mentioned the fuse, I was in the same situation, the fuse was not blown. But the prongs that hold the fuse had just enough corrosion on them so that it wasnt working (they looked good visually). I took the fuse out and wire brushed these and it worked. I know it sounds stupidly simple, but I felt extra stupid and simple when it worked for me.
