...Can anyone confirm this for me. I think I might have found a set from a 1976. Just want to make sure they are the double latch type. Thanks...
Capl27 has already confirmed it. 78. Anything before 78 is double latch. Everything after is single latch.
You can swap the two types by changing the halo panel hardware.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
if you are looking for additional head room look for the later ones with the smoked glass or plastic.....no headliner and one latch give you a lot of room
I was looking for more head room and thinking about not installing the "headliner", just painting the inside. Was looking on line and found one piece acrylic tops that would allow more head room but would also be much lighter. Anyone use one of these. How is the fit, etc? Are you happy with it?
Thanks,
Rob
