Front Control Arm Bushings
Old Mar 22, 2012 | 03:14 PM
texbeasr3's Avatar
texbeasr3
Default Front Control Arm Bushings
My polyurathane control arm bushings are falling apart after 5years and about 2000 miles. Maybe I over torqued them, because the bolts kept backing out? I am starting to remove the control arms, again, and would like your suggestions for front control arm bushings.
Old Mar 22, 2012 | 03:18 PM
Rebelrob's Avatar
Rebelrob
Tex, I did this less than a year ago. But I installed the OEM rubber. I was informed that you do not torque the bushing bolts tight until you have the car back on the ground under its own weight. Not sure if you did this or not, but it seems be very important in preventing in-proper wear.
Old Mar 22, 2012 | 03:42 PM
anips's Avatar
anips
because GM stock type bushings are bonded to the metal sleve the car has to be on the ground at ride height they have just so much twist in them, the poly's are different as they are not bonded to the sleve and work like a bearing, just make sure they are well greased with poly grease to avoid sweeks and wear.
Old Mar 22, 2012 | 04:15 PM
Mike Ward's Avatar
Mike Ward
And that's why the bolts back out too.
Old Mar 22, 2012 | 04:37 PM
anips's Avatar
anips
thats weird, never seen that happen before, the bolts are backin out of the cross shaft....do you have lock washers between the big washer and the bolts?
Old Mar 22, 2012 | 09:24 PM
81pilot's Avatar
81pilot
Thats what lock tight is for.
Old Mar 22, 2012 | 09:31 PM
81pilot's Avatar
81pilot
Poly wear is common if not greased enough or the wrong kind of grease is used. And lock tight will keep the bolts in. I had poly on my big truck for about 50K and never had them wear out. And the front of my Torino for 10 years before I sold it. But I would be hard pressed to recommend something to someone who has already had bad luck with it.
Old Mar 22, 2012 | 09:34 PM
bhk2's Avatar
bhk2
QUOTE=Rebelrob;1580349605]Tex, I did this less than a year ago. But I installed the OEM rubber. I was informed that you do not torque the bushing bolts tight until you have the car back on the ground under its own weight. Not sure if you did this or not, but it seems be very important in preventing in-proper wear.[/QUOTE]
I just installed the all ca bushings and waited to torque the bolts until after driving the car around. The AIM indicates 45-55lbs for the front bushings.
Old Mar 22, 2012 | 09:45 PM
billcarson's Avatar
billcarson
for those who don't want the hassle of reaching the upper a-arm bolts you can measure the angle of the cross shaft flat in relation to the arm with a home made tool and tighten them on your bench.this works only when replacing a rubber bushing for obvious reasons.
Old Mar 22, 2012 | 10:15 PM
anips's Avatar
anips
BTW, if the lock washers are there but when removed they are flat with no twist to em they are no good replace em with Grade 8's
Old Mar 23, 2012 | 11:36 AM
69 Chevy's Avatar
69 Chevy
Would you care to mention the brand name?
Old Mar 23, 2012 | 11:47 AM
texbeasr3's Avatar
texbeasr3
The poly bushings where the kind where the old hardware is required....I guess this was a bad choise. The Shaft bolts did have lock washers, but still backed out ot the cross shaft.
Rubber bushings seem to be the suggestion. What manufacturer would you recommend?
I am concerned about cheap rubber parts.
Old Mar 23, 2012 | 12:29 PM
Marlin's Avatar
Marlin
For rubber most name brands should be fine as lone as its not their service/builder/mechanic grade. Raybestos Pro grade is good.
But I had poly control arm bushing in my first car and they held up fine.
So make sure its not something on the car or the install that caused the probem as many here have run poly just fine. i.e. if you want poly run poly.
To Front Control Arm Bushings
