Front springs worn ????
Old May 17, 2002 | 12:45 PM
Guest
Guest
Posts: n/a
Default Front springs worn ????
I have noticed a difference between the clearance at fender to tire in the front of about 1" or 2 . Could this be my front springs ? I checked the frame and it looks to be ok . Can the springs wearout at uneven rates ? travis :confused:
Old May 17, 2002 | 01:12 PM
JerryM's Avatar
JerryM
Default Re: Front springs worn ???? (74dream)
If frame heights are the same side to side, it ain't the springs.
Springs can take a "set", if the car is driven with only one occupant most of the time, the left side will be generally lower. Also, constant sudden & severe applications of torque will do the same, as will a bent or sticking shock, or other binding in the suspension.
Hope this helps.
Old May 17, 2002 | 02:05 PM
John's Shark's Avatar
John's Shark
Default Re: Front springs worn ???? (JerryM)
do you have a/c? If so, is it the right side that is lower? Som of the compressors can add considerable weight to that side of the car.
Old Apr 8, 2016 | 10:41 AM
mortgageguy's Avatar
mortgageguy
Measure the distance from the ground thru the centerline of the hubcaps to the fender lip. See what the factory specs for your year car is, in the AIM. My 72 was about an inch low before I rebuilt the front susp. I did not replace the springs. It brought the ride height back to normal.
Old Apr 13, 2016 | 03:05 PM
Bronze85's Avatar
Bronze85
It can also be caused by worn out body bushings, unless they are the solid type.
Old Apr 13, 2016 | 03:53 PM
ddawson's Avatar
ddawson
Guys this is from 2002.
Old Apr 13, 2016 | 09:19 PM
mortgageguy
Crap! I have no idea how I pulled this thread up.
To Front springs worn ????
