81 electrical question
Old Mar 25, 2012 | 04:25 PM
Gmalibu004's Avatar
Gmalibu004
2nd Gear
Default 81 electrical question
Hey guys, I'm new to the forum and need some help. I have an 81 that had been converted from the smog/computer model - dist/carb. Car was sitting for 13 years before I found it. My problem is the battery keeps going dead and the tach shows 2000 with the key off. When you start it, the tach runs as normal.been trying to find the open circuit for a couple of weeks. Any Ideas/thoughts, before it goes to a shop.
Old Mar 25, 2012 | 04:57 PM
qwank's Avatar
qwank
Its normal for the tach to sit high with the key off, but usually it stays at the rpm it was idleing at when you shut it off. How old is the battery? if its the one that been in there the last 13 years, chances are its just junk.
Old Mar 25, 2012 | 05:50 PM
Gmalibu004's Avatar
Gmalibu004
2nd Gear
Thanks for the response. The battery is 3 months old. Car didn't have one when I picked it up. Also had to change ignition switch and reground the starter to get it running. Thanks for the info on the tach. I didn't know they did that.
To 81 electrical question
