81 seat cover install
Old Mar 27, 2012 | 01:45 AM
cyclops1032's Avatar
cyclops1032
Default 81 seat cover install
I am about ready to install new seat covers in my 81 Corvette. Anyone have any pics of the "during" installation? All I can find is before and after pics. Any advice? Also about the installation kit... Which one? What will I need? Thanks.
Old Mar 27, 2012 | 08:30 AM
thegazman's Avatar
thegazman
Default thegazman
MidAmerica Corvette has a free on-line video showing how to install seat covers showing the tools you will need. I did this a couple of years ago. Be sure and buy new foam is all I can recommend. I used a hair dryer to heat the material making it easier to stretch over the seat foam.
Old Mar 27, 2012 | 09:26 PM
texasbaehr's Avatar
texasbaehr
Thegazman makes a great point, spend the $ and replace the foam or the new covers will not look good over the old wore out foam. Even if it looks solid after you removed the old covers it has lost a lot of it resiliency and some thickness. If you can lay the covers in the sun to warm them up, makes installation much easier.
I will warn you, I hope you have strong hands becuase recovering seat is really tough on the hands. When you're done you'll know what arthritis feels like!
Old Mar 28, 2012 | 04:33 AM
cyclops1032
Thanks! That video was exactly what I was looking for.
Old Mar 28, 2012 | 04:37 AM
cyclops1032
Yes, I am going to use new foam. I recovered a set of seats in an old MG years ago. They just basically slipped over the foam and used hog rings to hold the covers to the seat frame. Nothing like the vette seat covers..lol.
Old Mar 28, 2012 | 09:08 AM
thegazman's Avatar
thegazman
Default thegazman
I read on here about someone who used plastic wire-ties to pull the wires into the foam creases. Could work very well as you could tighten them a little at time while you heated the material. This is one of the hardest part of installing seat covers and could be helpful. I haven't tried it myself. Just an idea.
Old Mar 28, 2012 | 10:09 AM
540 vette's Avatar
540 vette
I replaced the seat covers on my C5 and used wire ties. They worked great because they did all the work pulling the material tight.
To 81 seat cover install
