ZZ4 1974 Corvette
Old Mar 31, 2012 | 09:38 AM
deputy2u's Avatar
deputy2u
Default ZZ4 1974 Corvette
can anyone suggest what flywheel to use with the ZZ4 engine? i know it is supposed to be externally balanced and it came with a flex plate..i have a stock clutch and a stock muncie 4-speed and the flywheel i have is for the original two piece rear main engine i have now, so i cannot use it..i now need a flywheel for a one piece rear main....thanks for the help
joe
Old Mar 31, 2012 | 05:32 PM
deputy2u's Avatar
deputy2u
I have been on this board 8 years and have never seen a question posed without a number of answers....are all the guys with vintage Vettes gone?
Old Mar 31, 2012 | 05:59 PM
Mark Riles's Avatar
Mark Riles
Originally Posted by deputy2u
I have been on this board 12 years and have never seen a question posed without a number of answers....are all the guys with vintage Vettes gone?
Be a bit more patient. It's a nice Spring day. There are a lot of car shows today all over the country and I'm sure many members are either out driving or out working on their Vette. I'm sure you'll see some answers pop in tonight.
Old Mar 31, 2012 | 07:55 PM
deputy2u's Avatar
deputy2u
tks, Mark...you are probably right.
Old Mar 31, 2012 | 08:46 PM
loup68's Avatar
loup68
Army
Gm sells the correct flywheel. How did you get the ZZ-4 engine? I have a 68 with 327 and made the mistake ( I think ) of getting the smaller 10 1/2" correct one piece rear seal 153 tooth flywheel to keep the 68 only starter. I have had trouble with my clutch and original bell housing and clutch fork ball stud. You need the correct 11" 168 tooth(?) flywheel and I am assuming you already have the correct 11" bell housing and starter. Lou.
Last edited by loup68; Mar 31, 2012 at 08:50 PM. Reason: added a space between two words.
Old Mar 31, 2012 | 10:48 PM
deputy2u's Avatar
deputy2u
tks, Lou..that matches the info i have gathered so far..i do need the 11 inch clutch and i do have the right starter,someone just IM'd me the part number (GM 10105832) calls for 14" 168 tooth..i would like to find an aftermarket crossover flywheel and maybe get some info on a complete Hayes clutch...did not consider the fork ball stud..i guess i will get it all, clutch, fork and ball stud along with the flywheel, bell housing should fit, but i will check.
i found the ZZ4 engine on Craigs' list, about 2000 mile for $1500.00..a friend has an engine trailer so we are going to hook it up and see how it runs.
Old Apr 1, 2012 | 07:16 PM
ZZ71S's Avatar
ZZ71S
I used a steel Gm externaly balnaced 25 pound 153 fly whell and a center force 10.4 clutch and pressure plate with stock bellhousing and a mini starter works fine
With my zz4
Old Apr 1, 2012 | 10:15 PM
deputy2u's Avatar
deputy2u
Thank you...appreciate the help and you putting together that combination..since it works for you, that is exactly what i will do with my 74.. that way i do not have to experiment..thanks again...
joe
Old Apr 2, 2012 | 09:55 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
GM 10105832 is what you want to use.
Old Apr 3, 2012 | 07:59 PM
deputy2u's Avatar
deputy2u
ok, now i am getting confused again (not hard to do) i finally found all the specs on my ZZ4 and ZZ71S is using a Flywheel #14088650 which is a 12 3/4 inch and 153 tooth with a 10.4 clutch and has had no problems running or fitting this setup to his ZZ4 and stock bell housing (my 74 has a staggered starter and if memory serves me, this indicates a 168 tooth)...if i use the Flywheel #10105832 which is a 14 inch and 168 tooth, will this fit under my stock bellhousing and do i still use a 10.4 clutch or can i go to an 11 inch clutch? ..... AND thanks for all your help, guys, it is appreciated..
Old Apr 4, 2012 | 01:28 PM
Sigforty's Avatar
Sigforty
Stick with the number I gave you. That is what I put in my 71. I ran an 11 inch clutch with that. The 621 bellhousing your car has will work with both flywheel sizes. The higher horsepower cars and big blocks used a 14 inch flywheel with the 11 inch clutch.
Old Apr 4, 2012 | 06:47 PM
deputy2u's Avatar
deputy2u
thanks, Mark, what starter are you using, the ZZ4 block shows an straight bolt pattern but my stock block has a staggered bolt pattern and my starter has an iron nose.. so i guess i need a starter with a nose? thanks
joe
Old Apr 4, 2012 | 08:19 PM
deputy2u's Avatar
deputy2u
THANKS ALL, i finally got it all sorted out and i could not have done it without all your help, i have found a couple of aftermarket flywheel and clutch combinations as well as part number from GM, Napa and Zoom if anyone needs that information, let me know..i am always happy to give back..thanks again
joe
Old Apr 5, 2012 | 01:25 PM
Sigforty's Avatar
Sigforty
joe
I used the same starter that was on my original 350. My ZZ4 block was drilled for both starter types.
Old Apr 5, 2012 | 06:54 PM
deputy2u's Avatar
deputy2u
thanks, Mark, that is what i found in my block as well...Anyone want any crossover numbers for flywheels from GM to Aftermarket, let me know and i will post them..thanks, ALL.
joe
Old Apr 6, 2012 | 01:43 AM
Ralphbf's Avatar
Ralphbf
Off topic but I need to know... What spark plugs are you using?
I have ZZ4 heads on my 75 block.
Parts guys around here say they don't have that information.
Ralph
Old Apr 6, 2012 | 08:53 AM
deputy2u's Avatar
deputy2u
Ralph,
i have the ZZ4 Crate Engine Service Parts List and according to that, the plugs are:
GM part #19157987----R42LTS A/C Delco...8
hope this helps, i do not have a crossover yet since i have not gotten that far with my ZZ4.
joe
To ZZ4 1974 Corvette
Old Apr 6, 2012 | 12:28 PM
Ralphbf's Avatar
Ralphbf
I have never had a problem using the recommended plugs in anything.
But I have wasted time and money using other brands that crossed over on some body's chart.
Thanks again
Ralph
Old Apr 6, 2012 | 06:27 PM
Sigforty's Avatar
Sigforty
Ralph
I ran the Marine plugs that came in my zz4. The MR43LTS.
Old Apr 6, 2012 | 09:40 PM
deputy2u's Avatar
deputy2u
just found Summit sells these:
ACDelco R42LTS - ACDelco Conventional Resistor Spark plugs
Spark Plug, AC Delco, Each
Part Number: ACF-R42LTS
a little pricey, though...
