79 L82 QUESTION
Old May 18, 2002 | 01:35 AM
RALLYWHEEL's Avatar
RALLYWHEEL
Default 79 L82 QUESTION
I have a 79 l82 and want to do something to the engine compartment. Have any of yo removed the air ductwork in the engine? I have thought about getting rid of the air intake plastic thing and the ducts that lead to the air cleaner lid.I would like to replace with a chrome air cleaner. Will this affect the car in a negative way?What about valve covers? Do I repaint or replace? They are pretty expensive in catalogs. Thanks. :chevy
Old May 18, 2002 | 01:59 AM
tnt76vette's Avatar
tnt76vette
Default Re: 79 L82 QUESTION (RALLYWHEEL)
Some will tell you that you are drawing cooler air with your system intact.....I say once ya get movin it dont make any difference whether its there or not. I took mine off of my '76 when I did my mods, and went to a K&N 3" Filter which still fits under the Hood.....Not sorry but cant really brag abt any perf. boosts either :cheers:
Old May 18, 2002 | 02:58 AM
fauxrs's Avatar
fauxrs
Default Re: 79 L82 QUESTION (tnt76vette)
I think the cooler air makes a difference, but a significant one with all the twists and turns that air has to take? maybe not...if you like the look of the open element then go for it. Your car will be sucking much hotter air into the carb, on hots days you will probably notice.
Otherwise - no worries.
Old May 18, 2002 | 03:35 AM
79MakoL82's Avatar
79MakoL82
I yanked all that plastic duct work and crap and went with a Edelbrock drop base air filter. I haven't noticed a drop or improvement in performance. My opinion is, yank it out and go chrome. It looks a LOT cleaner!!! Plus, it SOUNDS cooler when you floor it. You can actually hear the roar of the engine.
[Modified by 79MakoL82, 1:38 AM 5/18/2002]
Old May 18, 2002 | 08:27 AM
Paul L's Avatar
Paul L
I prefer the stock look but that is simply a matter of taste. I doubt that you will see a noticeable change in performance if you modify as described. But it certainly will not hurt the engine. The valve covers can be painted with high-heat paint with good results. Again it is a matter of taste.
On what parts you intend to remove, they are expensive. So store them in case you change your mind. Or for the next owner. There is a segment of the market who prefer unmodified vehicles.
Old May 18, 2002 | 09:04 AM
killain's Avatar
killain
Oldtimer
I agree with Paul79 on saving the parts you remove, but there is also the matter of the air that is not blocked from going through the radiator. so I'd watch to see if the temps don't start rising.
Old May 18, 2002 | 09:28 AM
Vettesic's Avatar
Vettesic
Default Re: 79 L82 QUESTION (killain)
I agree with Killain, (Remember Killain, You sent me some foam stripping...worked great. Thanks again.)
RALLYWHEEL...I hade to remove the foward plastic air intake system, due to the fact that it would not allow the L88 hood to close all the way. I didn't notice any decrease of increase in performance, however as Killain stated in the previous post, make sure you block off the space that the ducting removal leaves with a foam stripping. (Home Depo 2" pipe insulation works well). The reason being, cool air must be directed to front of the rad. Makes for a cooler radiator envirornment on thos hot days. Good Luck, L8TER, Paul.
Old May 18, 2002 | 12:41 PM
79MakoL82's Avatar
79MakoL82
Default Re: 79 L82 QUESTION (paul79)
I agree, if you do choose to go with an open element, save the parts. I did. They are expensive and always a good thing to have if you ever decide to sell. As Paul79 said, it's a matter of taste. For me, I bought a 79 so that I could modify it the way I want and not feel like I'm ruining a museum piece. I like the engine compartment less cluttered looking, so I took it out, but I did save all the parts. Ditto on the pipe insulation between the radiator and the top of the support. That's what I did. I used three inch foam rubber pipe insulation and squeezed it in. the pressure holds it in and works great.
[Modified by 79MakoL82, 10:43 AM 5/18/2002]
Old May 18, 2002 | 01:21 PM
Schmucker's Avatar
Schmucker
Didn't the L48 hp go from 190 to 195 when the dual piping was put in? That means you get to draw twice as much air, right? Cold air makes more horsepower. By removing all the piping you now can draw a lot more air, but not as cold. It shouldn't make any difference then. There is a balance. Only when really hot will it matter. I say go cowl induction :) Keep the parts though, my dad still has all the original parts to his '64, so in theory we could take it back to original, but a 10 second drag car is too much fun :)
Old May 18, 2002 | 09:31 PM
79MakoL82's Avatar
79MakoL82
Default Re: 79 L82 QUESTION (Schmucker)
L48 never had dual piping. That was the L82 only. L48 had a single pipe.
Old May 18, 2002 | 10:13 PM
76Pitter's Avatar
76Pitter
Default Re: 79 L82 QUESTION (79MakoL82)
Personally I haven't had any problem without the piping. By the way, it was only the late 70's L-82 that had dual snorkels. Cheers.
[Modified by 76Pitter, 9:14 PM 5/18/2002]
Old May 18, 2002 | 10:16 PM
Paul L's Avatar
Paul L
Default Re: 79 L82 QUESTION (76Pitter)
In 1978 it was available on the L-82. In 1979 it was standard for both the L-48 and the L-82.
Old May 18, 2002 | 11:42 PM
Neo Fender's Avatar
Neo Fender
Negative. The '79 L-48 picked up the dual snorkel intake.
Old May 19, 2002 | 05:25 PM
Vettesic's Avatar
Vettesic
My 80 L82 has duel duel snorkels. And it's a bone stock, original motor.
[Modified by Vettesic, 3:30 PM 5/19/2002]
Old May 19, 2002 | 11:18 PM
razz1980's Avatar
razz1980
Default Re: 79 L82 QUESTION (Vettesic)
if i get a hold of a stock set-up i will take it to the track versus the open chrome set-up that i have and see which gets more air :p: the chrome set-up looks and sounds wayway better in my opinion..
[Modified by razz1980, 3:19 AM 5/20/2002]
Old May 20, 2002 | 01:19 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I just restored a set of center bolt valve covers for my newly rebuilt engine (in progress). I soaked them in mineral spirits, sand blasted them, wire brushed them, primed them, painted them, and then clear coated them. They went from rusty piles of garbage to looking sweet.
I had chrome covers, but I didn't like them. I want a sleeper.
Old May 20, 2002 | 01:21 AM
76Pitter's Avatar
76Pitter
Yes the 80 did have duels. So let me clarify...late 70's and 80.
Old May 20, 2002 | 01:19 PM
bigbobbyb's Avatar
bigbobbyb
You can easily (and inexpensively) upgrade your stock aircleaner by getting a chrome top cover and wing nut. That way you can have your cake and eat it too!! Corvette Central, Ecklers, etc... sell them.
Old May 24, 2002 | 12:36 AM
Justin79-L-82's Avatar
Justin79-L-82
Default Re: 79 L82 QUESTION (joeveto)
hahahahahahahaha.. a corvette it not a sleeper
To 79 L82 QUESTION
