Please let it be something stupid
Old Mar 31, 2012 | 01:21 PM
Toolman1953's Avatar
Toolman1953
Default Please let it be something stupid
Just finished the interior of my 77 when I first fired it up all gauges worked with the exception of the volt gauge (someday I will own a car that has a working gauge) ran good after sitting for a month but upon restart Temp gauge pegged and stayed there. I disconnected the battery as I do every night after any interior work because I don't want to burn the bosses shop down. Any ideas or checks that don't require pulling the dash down again? The only thing I noticed upon tear down was the vinyl circuit board? Where the harness plugs into it all the fingers became dislodged from it? If grounded when power is removed should it not return to zero? So close and now back three steps....
Old Mar 31, 2012 | 10:04 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I'd try using a Digital VOM and probe the connector at the dash for the Volt meter. See what you get.
temp gauge pegging indicates that you have a bad or incomplete ground at the dash and the cluster is using the Temp guage as its ground
Old Apr 1, 2012 | 11:43 AM
Toolman1953
But if i dissconnect the battery ground should the gague drop to zero degrees? I just don't want to tear the dash apart again
Old Apr 1, 2012 | 12:51 PM
AzMotorhead
I dont know if it'll drop to 0 without power. I cant recall what my gauge does when I remove the key. Cars been apart too long.
Old Apr 1, 2012 | 02:33 PM
tracdogg2's Avatar
tracdogg2
No, the gauges stay whereve they were at when power is disconnected.
Mike
Old Apr 1, 2012 | 03:41 PM
Toolman1953
Mike
where are the grounds located ? or do I trace back from the harness all other gauges are ok oil pressure clock
Old Apr 1, 2012 | 08:06 PM
drwet's Avatar
drwet
I think you're going to be pulling the dash apart again. If its any consolation to you, I had mine apart five times this winter before I got everything working at the same time. I ended up replacing the printed circuit board which solved a lot of the problems. I still ended up taking it apart one last time to get the vacuum switch on the heater control working properly. Welcome to the wonderful world of Corvette ownership!
Old Apr 2, 2012 | 12:28 AM
mrmagrath's Avatar
mrmagrath
As I understand it, if you disconnect the wire to the temp sender, it will go to zero, and if you ground the wire, it will peg. Willcox has info on how to read gauge symptoms, and there's plenty of subject matter here on the forum as well. Search is your friend!
To Please let it be something stupid
