73 l-48 AIR system
Old Mar 31, 2012 | 08:21 PM
Thomp's Avatar
Thomp
Default 73 l-48 AIR system
Two issues. First the main line coming from the back of the AIR pump going to the exhaust manifolds always blows out from the fitting. Any ideas why?
2nd. I just had the master cylinder and brake booster replaced. the car runs fine when in gear but when I come to a stop light and apply brakes sometimes it will die. sometimes it will idle fine then hic-up and die . Car restarts everytime but I have no idea what it could be. Only happens when in gear.
I can let it idle all day long in park and its fine.
To me it feels more like an electrical issue but i have no idea.
Any help would be greatly appreciated.
just to be clear 73 350 AT, AC no modifications all stock.
Thank you
Thom
Old Mar 31, 2012 | 10:31 PM
imariver's Avatar
imariver
Air pump issue....... could be a bad check valve. Idle issue........ check for a vacuum leak.
