Hi...new member
Old May 18, 2002 | 11:34 AM
Paul 77's Avatar
Paul 77
Default Hi...new member
Hey guys, I just wanted to say hi, I have been reading this forum for some time now and really enjoy the information and experience’s you guys share with each other. I have been registered for a while but could never seem to get logged on. It seems the problem is with my zone alarm fire wall…when I have it running I cannot get logged in, when I turn it off I can get right in…anyone else with this problem?
I have recently purchased a 1977 Tan Corvette and as soon as I get it back together I will try and get a picture of it on this forum. As of now it runs good, just got it to pass inspection (New Jersey) and I am finding out all the different ways I can spend money on this car.
I am currently trying to get the heater/defroster/vent control to work, it seems it is controlled by vacuum, as far as I can tell I have no vacuum getting to the control switch and one of the lines appears to be missing. To make matters worse (things with this car are always worse) my driver side vent is missing, (this would be the vent by the kick panel) I am guessing that the car was in an accident and it just didn’t get replaced. If anyone has worked on these vacuum lines and can offer any advice I would appreciate it. Thanks
Old May 18, 2002 | 12:12 PM
Ganey's Avatar
Ganey
Default Re: Hi...new member (Paul 77)
Paul
Welcome. Congrats on the 77, a very good choice of years. See my website 77 Facts.
:cool:
FAST FIX by GANEY
The problem is that heater is the default position (no vac. or vac. leak) due to being designed in the north. Vent should be default. Very safe bet the problem is 1 OR 2:
1) The vac. line from engine is damaged from heat - a small plastic tube that goes in below the hood theft switch into wiper valley. Replacing most of engine side w/ hose will fix. OR
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ white lithium grease or vasoline to fix.
3) If you have a heater, the hose underhood probably also needs replacing. Block w/o heater.
PS The design problem comment is not intended to be offensive to any of our northern friends. :cool:
Old May 18, 2002 | 12:14 PM
paso's Avatar
paso
Welcome Paul 77 Please enter your data in the 77 registry linked below:) glad to see you aboard. Nice handle I could have used it also :D
Old May 18, 2002 | 12:44 PM
One GM A Tech's Avatar
One GM A Tech
welcome Paul I have a highly modded 77 also good luck and enjoy :cheers: :cheers: :cheers:
Old May 18, 2002 | 01:16 PM
Indy Year 25's Avatar
Indy Year 25
Default Re: Hi...new member (Ganey)
Welcome Paul!
I replaced the one on my '78. The line that was on it actually looked like a white electrical wire. Searched and could not find the tube. NAPA recommended, and I used, air shock tubing. It worked fine but, I am keeping an eye on it to make sure it is not heat affected.
Old May 18, 2002 | 02:20 PM
vettedan's Avatar
vettedan
paul- Welcome to the Corvette Forum!
Old May 18, 2002 | 02:28 PM
Binnie77's Avatar
Binnie77
Welcome Paul...'77 is a good year :D
Old May 18, 2002 | 02:44 PM
ROD NOCK's Avatar
ROD NOCK
Welcome Paul 77! Yep, agree w/Ganey's Fast Fix on heater/vent control!
Good Luck on your project -Rod :chevy
[Modified by ROD NOCK, 1:46 PM 5/18/2002]
Old May 18, 2002 | 03:57 PM
78Vette-SA's Avatar
78Vette-SA
Hi Paul,
Welcome!
If you don't already have it, get a copy of the AIM (Assembly Instruction Manual). It has diagrams of how everything should go together, is available form any Corvette Vendors (Zip, Mid-Aermica, Corvette Central, Ecklers, etc) and is only about $25 with the index.
:smash:
Old May 18, 2002 | 04:24 PM
82dukman's Avatar
82dukman
Default Re: Hi...new member (78Vette-SA)
welcome to the forum. I second the motion to get an AIM. I have it for my 82 and it has helped hunderds of times.
Old May 18, 2002 | 04:56 PM
Stingraycrazy's Avatar
Stingraycrazy
Paul,
Welcome to the fourm. I've been a member for about a month and the Information you can get here is Awesome! Good luck toward your 77.
Frank's just StingRayCrazy 72 Twin Turbo :cheers:
Old May 18, 2002 | 06:36 PM
Paul 77's Avatar
Paul 77
Well I found out what the problem was, I will be getting a copy of that AIM guide asap. I was thinking this was a vent that would provide a little floor circulation. This car is hot as hell even when I have the tops off…I though the floor vents were not working…I guess this car doesn’t have floor vents…I finally got this vent to open when I put the AC switch to the max position. This must the recycle vent to put cabin air back to the AC. Oh what fun! Thanks for your suggestions…I took everything apart and cleaned it, the switch has plenty of vacuum now. Can anyone tell me how to post a picture?
Old May 18, 2002 | 08:58 PM
LeAnn82Collector's Avatar
LeAnn82Collector
:seeya
Old May 18, 2002 | 08:59 PM
LATNC3's Avatar
LATNC3
WELCOME TO HEAVEN :blueangel: :blueangel: :blueangel: :blueangel:
:cheers: :cheers: :cheers: :cheers:
Rod :cool:
Old May 18, 2002 | 10:45 PM
Ganey's Avatar
Ganey
Paul
There is a duct at bottom of dash that ducts air to the dr. side vent.
Altered mine to put some a/c to the floor.
:cool:
Old May 19, 2002 | 03:34 AM
Chuck Harmon's Avatar
Chuck Harmon
Welcome Paul! It's great to build up our ranks of small block C3's. We've been losing some of the small block members of our C3 forum lately to a highly contagious and frequently terminal illness. Alas, poor Bence, he was such a good kid. :nopity
Anyway, glad to see you with us!
Chuck
Old May 19, 2002 | 11:39 AM
Flareside's Avatar
Flareside
Hey Paul, we're neighbors! I just moved from Hopatcong to Roxbury last year. Welcome to the forum.
If you're not already planning to attend, think about driving up to the Ramapo College Corvette show on June 9th. Lots of guys from the forum will be there.
-Joe
To Hi...new member
Old May 19, 2002 | 05:43 PM
JRD77VET's Avatar
JRD77VET
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Default Re: Hi...new member (Binnie77)
Old May 19, 2002 | 05:48 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Hi...new member (JRD77VET)
welcome paul,congrats on getting it through new jersey inspection thats the biggest thing so far its all downhill from here. :yesnod: theres plenty of mods to do on a vette.
Old May 19, 2002 | 07:20 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: Hi...new member (pats406nitrovette)
welcome aboard Paul- Heck move to South Florida and you can cap off those fresh air vents and run the A/C 24/7/365. No emmisions testing either. A corvette hevean. Just kidding- welcome aboard. Now for the real advice- forget about the vent and install a cam.
