ENGINE COOLANT TANK REPLACMENT??
Old May 18, 2002 | 04:48 PM
OkeeGuy's Avatar
OkeeGuy
Default ENGINE COOLANT TANK REPLACMENT??
everything under my hood looks pretty awesome (pure stock, original)
EXCEPT for the coolant overflow tank...
my guess is that it looks like crap cause nobody want to change it cause its a PITA....is it?
oh ya...of course it is air conditioned...yikes!
whats the deal here...is it hard to do?
Old May 18, 2002 | 04:58 PM
MIKER's Avatar
MIKER
Default Re: ENGINE COOLANT TANK REPLACMENT?? (SIGNGUY)
To clean my overflow tank, I removed it, filled it ~1/3 full with a mixture of Castrol Super Clean and kitty litter. I used duct tape to seal it up and shook the hell out of it off and on for a couple of hours. Drain and rinse.
It won't make it look like brand new but it was a huge improvement.
Old May 18, 2002 | 06:18 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: ENGINE COOLANT TANK REPLACMENT?? (MIKER)
i want to replace it with a new one...what im wondering is how hard is it to remove from an a/c car??????
Old May 18, 2002 | 06:22 PM
MIKER's Avatar
MIKER
I removed mine while the engine was out so I can't really provide you with the information you need.
It was certainly easy enough to remove and install when I did it. :D
Old May 18, 2002 | 11:30 PM
madmaxgt's Avatar
madmaxgt
Just had mine out on my 75 today. Don't know if there the same, but here goes.
1) Remove front P-side wheel.
2) Remove two (2) 3/8 bolts that hold tank.
3) Take take out of fender well through engine compt.
4) Drink Beer! :cheers:
Old May 19, 2002 | 12:54 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: ENGINE COOLANT TANK REPLACMENT?? (madmaxgt)
looks like a lot of a/c stuff in the way as i recall...ill have to look again tomorrow...
does yours have a/c???
Old May 19, 2002 | 01:08 AM
madmaxgt's Avatar
madmaxgt
Yep! But the Compressor was off, didn't think about that! Should still be able to manuver it, might have to unbolt the bracket to make it clear! :flag
To ENGINE COOLANT TANK REPLACMENT??
