A/C fast idle solenoid bracket
Old Apr 5, 2012 | 03:08 PM
conway62's Avatar
conway62
Default A/C fast idle solenoid bracket
I have a Demon 750 and would like to add a fast idle solenoid. I tried the Holley bracket but not way even with modification will it fit. has anyone fabbed a bracket or found one that will fit? I cant believe Barry Grant never made a bracket for this purpose. The holes are in the base plate but because of their clunky linkage the holley bracket will not fit. Very frustrating. Any pics of brackets would be awesome
- Ron
Old Apr 5, 2012 | 05:35 PM
oldalaskaman's Avatar
oldalaskaman
get one from a mid 80's Q-jet
Old Apr 5, 2012 | 06:36 PM
toddalin's Avatar
toddalin
On my '64 I mounted a solonoid to the windshield washer pump screw. The solonoid pulls a "ball chain" (like used for cruise control) and I can adjust the amount of pull by switching *****. I also made a small "turn buckle" out of two "ends" and a small screw to fine tune the adjustment. The chain then attaches to the throttle linkage to pull it.
I can use it for a fast idle (no choke tower on my Holley) or to set a launch RPM. It's real nice when you have a cold engine and approach a stop light. You can flip the switch and not worry about stalling.
I have a switch under the dash that activates it.
Old Apr 5, 2012 | 06:59 PM
oldalaskaman
you have an answer in your other duplicate thread also
Old Apr 5, 2012 | 07:00 PM
corvetteload's Avatar
corvetteload
write to Barry Grant and see how well that works out...........
Old Apr 6, 2012 | 04:43 PM
conway62's Avatar
conway62
Thank everyone but it doesnt sound like anyone has any solid ideas. Im very surprised that no one has done this. Well I guess Ill try to fab something that will work. Ill post some pics if I come up with something that I think people may like.
To A/C fast idle solenoid bracket
