intermitant miss
Old Apr 6, 2012 | 07:02 PM
tgcattle's Avatar
tgcattle
Default intermitant miss
I know tis prolly ain't the right forum. But there seems to be alot if knowlege here. So I'll ask my question. I have a 2000 C3500 chevy truck with a 454 multi port fuel injection. It has started to miss and kinda buck but only sometimes. sometimes on take off sometimes at highway speeds sometimes not at all. I changed the plugs,wires,dist. cap and rotor. Ran good for couple of weeks the started missing again. Checked fuel pressure 60psi. I was thinking maybe the coil, ignition control module or cam position sensor. Any ideas or direct me to someone who may know? It is not setting any codes. I have 122000 miles on it
Old Apr 7, 2012 | 12:21 AM
TimAT's Avatar
TimAT
I had a problem with a coil- it was the HEI remote mounted coil- it would fire theu the insulation and into the core so you couldn't see it. You could hear it- when the engine would stumble you could hear the snap.
Put a little dish soap into a spray water bottle and soak the secondary side. Coil, wires, cap, everything. The soap slows the evaporation rate.. Bet you find it.
Old Apr 7, 2012 | 08:08 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Fuel filter perhaps.
Old Apr 7, 2012 | 09:46 AM
KB9GKC's Avatar
KB9GKC
Clean the MAF sensor, sometimes dirt/debri gets past the air cleaner filter.
Douglas in Green Bay
Old Apr 7, 2012 | 10:08 AM
Jeff_Keryk's Avatar
Jeff_Keryk
I used to burn plug boots on the header. Had to dimple the header. It would run fine for awhile, then miss. View the running engine in a dark area and look for the show.
To intermitant miss
