Shocks/Leaf Spring Bushings/Master Cylinder?
Old Apr 11, 2012 | 09:04 PM
Alwyn678's Avatar
Alwyn678
Default Shocks/Leaf Spring Bushings/Master Cylinder?
Any recommendations? My 74 still has original Shocks and all original bushings. Any ideas on the best replacements? I am also going to need a new Master cylinder.
Please give me some good options for my issues............
Is "bolt cinch" a good idea for bolts that have some leakage around them?
Old Apr 12, 2012 | 10:36 AM
MelWff's Avatar
MelWff
For shocks depends on your budget. Bilstein is a very good choice but cheaper alternatives such as KYB, Delco are available. For the master, if not excessively corroded buy a rebuilt kit.
Old Apr 12, 2012 | 11:42 AM
retrodude's Avatar
retrodude
I really like the KYB, good price and good ride.
Master Cylinder...go Chrome, it will make your car faster...haha
I agree, do a rebuild kit, not much in there...
Old Apr 12, 2012 | 12:31 PM
doctorgene's Avatar
doctorgene
Yes Sir; Melwff & retrodude are right on. How much money do you want to spend. I used Bilsten after 2 different sets of the lower priced, you can immediately feel the difference. Master: Sure Stainless Steel sleeved Chrome. Easy to clean, & check for leaks. no rusting, or painting required. Bushings on suspension: I used stock rubber, on A-arms & Trailing Arms, But Frt, & Rr. Sway bars & Springs I used Poly. Vette Brake Products Touring springs frt. & Rr. Heavy duty tie rods sleeves & lock-nuts. Heim joint rear Strut bars, Speed Direct Shark Bite Sup. Spreader Bar. Where do you wan to stop. Have a ball & a great week. Gene
To Shocks/Leaf Spring Bushings/Master Cylinder?
