TPI swap with a modern twist
Old 04-12-2012, 12:29 AM
moonsteel
Holley HP EFI w/TPI
Support Corvetteforum!
moonsteel's Avatar
Default TPI swap with a modern twist
Let the auto tuning begin
Old 04-12-2012, 12:28 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Started with the fuel pump, chose Tanks Inc in tank setup.
http://forums.corvetteforum.com/c3-t...p-install.html
Old 04-12-2012, 12:34 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Ordered parts from Summit
Old 04-12-2012, 12:36 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Bought used TPI Intake from an 89 IROC
Old 04-12-2012, 12:57 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
That the new Holley system?
Whats the hp limit on those do you know?
Old 04-12-2012, 03:46 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Yes, the HP. This package has wiring/sensors for the TPI.
I would guess that its injector dependent, rather than the ecu.
What hp do you need to fuel?
Old 04-12-2012, 08:47 PM
bruced267
bruced267's Avatar
I will be watching this one! I have the same kit...looks like you are closer than me! Body is still off.
I got a kit from Moore Raceraft, I think they designed it(?) I also went with the daul snyc dist. for Multi Port efi. The touch screen and gauges look interesting?
Old 04-12-2012, 09:17 PM
6inarow
6inarow's Avatar
If its not too much to ask,could you let us know approximately what you have paid for the parts you have in this project as you go?
Old 04-12-2012, 09:47 PM
drwet
drwet's Avatar
[QUOTEWhats the hp limit on those do you know?[/QUOTE]
Word on the street is the limiting factor on the factory TPI system is the size of the runners and injectors. The system was originally designed for a 305. When installed on a 350 it runs out of breath at about 5000 rpm. There are aftermarket runners available and of course bigger injectors.
Old 04-12-2012, 09:51 PM
cv67
cv67's Avatar
St. Jude Donor '05
Wondering if it could feed 600 +-
Not that I want to put FI on it but it all looked well over time. Maybe.
Probably not but maybe
Old 04-13-2012, 08:29 AM
Rotonda
Rotonda's Avatar
Just as with the earlier (82/84) crossfire injection, the manifold base plate is very restrictive. You can increase your throttle body flow, port the plenum and put on larger runners and get a little more, but you're not going too far without addressing the restrictions in the base plate (and heads). Suggest that you look at the vortec heads and matching base plate to get more power and rpm and really use the money that you put into the top of your engine.
Old 04-13-2012, 08:36 AM
6inarow
6inarow's Avatar
Maybe the C4 is less restrictive than the IROC OR Firebird?
Old 04-13-2012, 08:37 AM
cv67
cv67's Avatar
St. Jude Donor '05
They run out of breath about 4k or so.
Work with a lot of those TPI systems (meaning porting)
A heavily worked aftermarket base, runners and plenum will bump things up a nice notch. Thing is the cost. Just got done with a members SLP system. By the time he bought the stuff had it all ported to the max and polished hes easily in the intake over $1500.
Cam it the opposite of the way you would a carb. 2teens in the intake...even on a 383.
If you really want a killer TPI system look into the FIRST intake system
about $850 w/a throttle body. Its a king sized beast.
They are now coming out with a 2" dia runner, too. Nice.
Old 04-13-2012, 09:53 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Word on the street is the limiting factor on the factory TPI system is the size of the runners and injectors. The system was originally designed for a 305. When installed on a 350 it runs out of breath at about 5000 rpm. There are aftermarket runners available and of course bigger injectors.[/QUOTE]
Very true, but my car has a basic 350 and only sees road duty (drive to work, corvette club cruises etc).
I was concerned more with driveability, rather than peak power.
Old 04-13-2012, 09:56 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Any programmable EFI kit can handle 600 hp, IIRC that's about 50lb injectors.
Old 04-13-2012, 10:01 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Sure. I'll leave shipping and taxes out (I live in Canada).
TPI used $250 (I've seen them as much as 400-500)
Holley HP EFI $1500
Tanks Inc PA-4 fuel pump $250
How detailed a breakdown do you want of all the kibbles and bits?
Old 04-13-2012, 10:03 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Agreed, time and $$ limit me to one project a year
To TPI swap with a modern twist
Old 04-13-2012, 10:12 AM
cv67
cv67's Avatar
St. Jude Donor '05
That cost isnt bad at all. Figure a few hundred for odds and ends?
What about a distrinutor/ign how does that work out with that system?
If the op is just using his 350 as a cruiser suppose thestock TPI will get him around fine.
If in search of a lot of power almost not worth it the runner length as a whole is the limiting factor.
They have great throttle response and torque on the street though.
Old 04-13-2012, 10:13 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
For people thinking about this, here's some info about my choices
Why TPI?
Lots of them available used
lots of aftermarket support/options
fits under the stock hood
driveability
Why not EZ-EFI or Holley Avenger TBI?
I figured if I was going EFI, I'd use a manifold designed for EFI.
carb look isn't important to me
8 injectors vs 4
Why Holley HP EFI vs others?
TPI retrofit kit makes it plug and play, contains all the harnesses, sensors etc
'Autotune' makes initial tuning easier
Price point
ability to control timing
ability to run sequential injection
Why Tanks Inc PA-4
in tank pumps tend to last longer and are quieter
Old 04-13-2012, 10:21 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Probably 300-400 in fittings, fuel lines, gaskets, air filter, throttle cable.
2500 was my target for the install
Many options
1) No control, tach signal to ECU
2) Use TPI Dist, comes with plug, have ECU control timing
3) Use other locked/electronic dist, have ECU control timing
4) Crank trigger, have ECU control timing
Nothing preventing you from using #1, then switching later to 2-4
TPI has endless options as well, ported base, larger runners, FIRST, HSR, miniram etc
Nothing to prevent me from changing to a better flowing setup in the future.
TPI + HP EFI leaves me with endless options
Quick Reply: TPI swap with a modern twist
