Courtesy lights ground location
Old Apr 13, 2012 | 12:48 AM
19Tyler74's Avatar
19Tyler74
Default Courtesy lights ground location
Hello all,
Was putting the Vette back together, got everything working and wired correctly... then the courtesy lights decided to go out...
I believe that it is a ground issue - perhaps one got pulled when I was situating the radio etc. back into place. None of the fuses are blown...
Any ideas?
Thanks!
Old Apr 13, 2012 | 08:17 AM
Roco71's Avatar
Roco71
The ground comes from the switches in the door jams. The positives I believe are tied in with the clock and cigar lighter are they both working?
Old Apr 13, 2012 | 09:30 AM
Sully1882's Avatar
Sully1882
the courtesy light get their ground from the point where they are screwed into the door jam. You should be able to just touch the switch to the hole and the lights come on. Commonly the little tabs that go into the switch are loose and allow the wires to come out. DO they not come on with either door opening up?
Sully
Old Apr 13, 2012 | 11:12 AM
19Tyler74's Avatar
19Tyler74
Neither is currently coming on... may have plled something loose?
To Courtesy lights ground location
