78 Engine Swap
Old Apr 15, 2012 | 04:21 AM
aefalcone1's Avatar
aefalcone1
6th Gear
Default 78 Engine Swap
So after I get the wiring problem fixed Im considering putting a new engine in. After looking on the forums I came across this engine http://www.enginefactory.com/350hp.htm from what I have read about putting it into a 78 it doesnt require a lot of other work like chassis reinforcement or anything like that. If anyones familiar with crate engine swaps what am I getting into here and am I on the right track. Im looking to add more hp but nothing crazy just want more responsiveness behind the pedal. thanks
Old Apr 15, 2012 | 10:01 PM
jackson's Avatar
jackson
$5800 ... too much for 350hp ... lotsa dough for lotsa cheap chrome & BS.
look at year one 400hp roller cam crate for $3000 ... year one p/n CT350PC1
Old Apr 16, 2012 | 02:58 PM
aefalcone1's Avatar
aefalcone1
6th Gear
thanks for the help
Old Apr 16, 2012 | 03:03 PM
billla's Avatar
billla
St. Jude Donor '14
Why put in a new engine? Is the current one running fairly well? How many miles are on it?
Old Apr 16, 2012 | 05:07 PM
aefalcone1's Avatar
aefalcone1
6th Gear
Engine is fine it only has 53k im just looking for more speed. I was debating if I should work off the original engine or just get a crate motor. What are the basic upgrades I can do to the current engine? Cams, headers intake? This is my first project car so im all ears to suggestions.
Old Apr 16, 2012 | 05:43 PM
billla's Avatar
billla
St. Jude Donor '14
The short answer is that there are a ton of upgrades you can do if the engine is healthy.
Do compression and leak-down testing and post the results
To 78 Engine Swap
