68 L36 Power steering pump
Old Apr 15, 2012 | 07:11 PM
ST3Andy's Avatar
ST3Andy
5th Gear
Default 68 L36 Power steering pump
Here's my issue. Reassembling the front of the motor. Replaced power steering pump but could not get the original style pump. Was told the pump will fit, it does, but after installing the alternator, I cannot remove the ps pump cap. It hits the brace for the alternator. Does the pump reservoir style make a difference? First post rookie
Old Apr 15, 2012 | 10:55 PM
RobRace10's Avatar
RobRace10
The original pump had an angled neck. I had the same problem with a straight neck pump, did some shimming and as I recall used a different cap to get it so I could get the cap off.
Old Apr 15, 2012 | 11:22 PM
Jim Shea's Avatar
Jim Shea
Could you just reuse the reservoir from your original pump? Reservoirs for all Saginaw P-pumps will interchange.
Jim
Old Apr 15, 2012 | 11:26 PM
Ironcross's Avatar
Ironcross
Jim
exactly......
Old Apr 16, 2012 | 07:14 AM
ST3Andy's Avatar
ST3Andy
5th Gear
I had a core charge on the original. I cant see shimming it, its that far off. So looks like i will have to chase down an original style unless someone has another suggestion?
To 68 L36 Power steering pump
