Leaky power steering unit
Old Apr 16, 2012 | 11:14 AM
VetteNURSE's Avatar
VetteNURSE
Default Leaky power steering unit
Hey there, Whats the best way to go with a leaking power steering unit? Is it worth trying to fix or is a new unit in order. Sick of my 76 peeing on my nice garage floor.
Old Apr 16, 2012 | 11:33 AM
MelWff's Avatar
MelWff
what component is leaking, the hoses, the control valve, the cylinder, the pump, etc.?
Old Apr 16, 2012 | 12:16 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I ended up replacing it all in my 80. From what I've experienced and read, if one part is bad then the rest will soon follow. New hoses, ram and control valve all at the same time for peace of mind.
VetteNURSE's Avatar
VetteNURSE
Sorry, Control valve
Old Apr 16, 2012 | 01:19 PM
jcloving's Avatar
jcloving
I am replacing all of my components now too. Box is in, pump is in, Control valve is in but can't get the hoses to connect. Cylinder is next.
Mounting that control valve to the rod was the most strenuous thing I have done yet on this car.
I was also tired of a sticky, leaky mess down there.
Old Apr 16, 2012 | 02:03 PM
iokepakai's Avatar
iokepakai
One of the best upgrades I did was install a Borgeson steering box.No more control valve and no more leaking hoses under the car.Bolts right up looks stock and steers great.[IMG][/IMG]
[IMG][/IMG]
Old Apr 16, 2012 | 02:05 PM
MelWff's Avatar
MelWff
Just replace the valve, much easier than trying to fix.
Old Apr 16, 2012 | 02:38 PM
VetteNURSE's Avatar
VetteNURSE
What was so difficult and why did the hoses not connect? I just ordered it all from wilcox.
Old Apr 16, 2012 | 02:54 PM
MelWff's Avatar
MelWff
Personally I had no problem, after disconnecting valve and hoses and loosening clamp it unscrewed. Make sure you note the position of the hoses, a picture would be best, before disconnecting them.
Old Apr 16, 2012 | 07:30 PM
aussiejohn's Avatar
aussiejohn
[IMG][/IMG]
It's the best thing you can do to make your car steer like a modern one. Next would be a spreader bar, then crank as much positive caster into the stub axles as you can. Around 5-7 degrees, if you can get that much.
Regards from Down Under.
aussiejohn
Old Apr 17, 2012 | 11:17 AM
VetteNURSE's Avatar
VetteNURSE
Aussie john, what will that do for me?
To Leaky power steering unit
