DD2000 Question
Old May 19, 2002 | 09:49 PM
ORVette's Avatar
ORVette
Default DD2000 Question
Just wondering. How come, when I enter the specs of some mild SB combo's that have been dynoed in magazines, I always get much higher HP and TQ figures? Also though, when I enter specs from dyno'd combo's like the Edelbrock RPM crate motor, or the Holley SystemaxII, I get a lot less than what they report. I entered the Holley combo with the exact cam specs from Lunati and flow #'s from CHP for the heads, all the right CR and header size, and the best I can get is like 370HP and like 380TQ. Just wondering.
Old May 19, 2002 | 10:02 PM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
Default Re: DD2000 Question (ORVette)
Depends on the type of dyno'ing you are set up for.. Are you set up for Rear wheel horsepower, or Crank? Are you corrected for altitude? There are literally about 50 different explanations for the difference in results.. Others here may be able to get more in depth..
_MM
:cheers:
