1980 air conditioner problem
Old Apr 19, 2012 | 04:57 PM
hensley73's Avatar
hensley73
Default 1980 air conditioner problem
I have a 1980 Corvette. I have been having air conditioner problems. I checked that computer and the book and they both show that the black wire on the compressor is the ground. The black wire on mine is hot. Does anyone have any suggestions?
Old Apr 19, 2012 | 08:36 PM
drwet's Avatar
drwet
Without checking a wiring diagram, I have to assume you have the air conditioning turned on. This will make the ground appear to be hot, for obvious reasons.
Old Apr 19, 2012 | 08:48 PM
sweeet76's Avatar
sweeet76
If you use a volt meter and measure (with the ac on) the black wire to ground, do you get 12 volts dc? If so, the black wire is hot, however I don't know if that's the way it is suppose to be.
Old Apr 20, 2012 | 09:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What type of AC problems are you having?
Old Apr 20, 2012 | 01:57 PM
hensley73's Avatar
hensley73
The compressor isn't working. I checked the book and the black wire is suppose to be the ground and the green wire is suppose to be hot. I checked them and the black wire is hot and the green one isn't.
Old Apr 20, 2012 | 02:08 PM
Easy Mike's Avatar
Easy Mike
I would look back along the AC wiring to see if Bubba may have made some repairs.
Green should be hot; black should be ground.
Old Apr 20, 2012 | 03:52 PM
EmNash's Avatar
EmNash
The #1 cause for the compressor not engaging is low refridgeration pressure. It will not turn on with low pressure unless you bypass the low pressure sensor.
To 1980 air conditioner problem
