T trop trim removal
Old Apr 20, 2012 | 11:17 AM
VetteNURSE's Avatar
VetteNURSE
Default T trop trim removal
Does any one know how to take off the ss trim around edge of the t tops?
Old Apr 20, 2012 | 12:01 PM
Mooser's Avatar
Mooser
Check the AIM for the screw locations (don't know your year), mainly along the door glass WS. There is one on the small SS piece that covers the joint.
Once all of those are gone he stuff is just sort of "clipped" on, some (or someone) might have put a little adhesive to hold them.
I took a small block of hardwood with a nice sharp corner and put it against the trim and tapped with a small hammer and just worried my way around and it popped off nicely.
I did mine when it was going for paint so it didn't matter but if I had to do it on good paint I'dd put a strip of masking tap on top to protect it from the wood maybe
Mooser
Old Apr 20, 2012 | 02:05 PM
Roco71's Avatar
Roco71
Mooser
I used a paint stick to work mine off.
Old Apr 20, 2012 | 02:31 PM
69ttop's Avatar
69ttop
it's not hard, but putting them back together right is the tricky part.
the trim along the front is shaped like a channel with teeth on the underside. the teeth are what holds it to the fiber glass and as it travels around to the side it fits into a clip. the side moulding is held into place with pop rivits. you will have to drill out the rivits. this is the thing though, the rivits are counter sunk so they are flush with the trim surface so the weather stripping fits flat with out gaps the could leak. i could not find counter sunk rivits so i made my own by drilling a hole that is the same diameter as the original rivit through a 1/2 inch piece of steel then counter sinking the hole with a larger bit. the 1/2 inch piece of steel is an anvil that is put in a vise. remove the pin from a new rivit. place the rivit in the hole and tap it with a hammer to change the shape to counter sink. reinstall the pin. make new rivits as needed.
i think there are a few screws to be removed also.
To T trop trim removal
