70 wont start
Old Apr 20, 2012 | 02:47 PM
his and hers's Avatar
his and hers
Navigator
Default 70 wont start
my 1970 turns over but wont fire. Ran well last week. Any thoughts?
Old Apr 20, 2012 | 03:45 PM
MelWff's Avatar
MelWff
well it's either gas or spark. Twist and pull one of the spark plug wires off at a plug and insert a insulated screwdriver into the end of the wire. While holding the insulated end of the screwdriver hold the metal shaft near any metallic part of the engine while someone tries to start the car. If you have a spark we now have to check for fuel. Remove the air cleaner assembly and look down the front/primary side of the carburetor, you may have to hold the choke blade open. Manually move the throttle assembly and you should see gas squirt into the front half.
Old Apr 20, 2012 | 04:19 PM
Vette5.5's Avatar
Vette5.5
Actually most auto parts places carry spark testers for about 5 bucks. Probably a good thing checking for spark first.
Old Apr 21, 2012 | 10:21 AM
69 Chevy's Avatar
69 Chevy
Neutral safety switch
Old Apr 22, 2012 | 09:14 PM
daytona yellow's Avatar
daytona yellow
My 70 had an external type that was plugged with grit & small rusted metal. Replace the filter & it started right up!!!!
Good luck
To 70 wont start
