Bubba wired rear tail lights-pics and 3 questions
Q2 PO connected red wire from outside light to inside light. Is this wiring correct? Answered my other two questions by searching the Forum, should have done that first.
I can help with Q1: You should be fine splicing wiring, but use a waterproof butt connection. You crimp these on to the copper, then a heat-shrinkable sleeve provides a water-tight seal. Sounds like you're in luck if you can match the original connection by wire color.
Received 1,470 Likes
Cruise-In II Veteran
What year? I'm guessing 69 and later and the PO wanted four rear lights like the 68s.
