Harmonic Balancer replacement
I removed the HB this evening, with the Proform tool it could not have gone smoother. The hardest part of the whole process so far has been removing the power steering belt, the power steering pump did not want to pivot out of the way.
After researching this forum for the HB and tool that I bought, I also found that I would not have to remove the fan shroud to get the HB out. There is plenty of room to use the tool. When I first started cranking (pun intended) on the removal tool collar, I let the 3/4 wrench turn with the crank until it was lodged against the fan shroud, holding it in place. This made the rest of the removal a one-handed process.
Also from this forum (the Search button is my friend!) I saw the front main seal can be removed leaving the timing cover in place. I was concerned about damaging the cover trying to pry the seal out, so I tried cutting it out. It worked pretty well, took less than 10 minutes, including stops to take a few pictures. Since I could not find any step-by-step tips, here is how I did it.
First, I cut across the front-facing surface of the seal with large diagonal cutters. I cut on the bottom edge of the seal, careful to ensure any metal fragments fell to the ground and not into the cover:
Then I made a second cut about an inch away from the first cut, and removed the face of the seal between cuts using the diagonal cutters. This left a flat surface between the cuts that easily bent upward, reducing the OD of the seal and allowing it to pop out.
I did leave a few scratches on the face of the timing cover, but no deformation of the cover, and no scratches where the new seal will sit.
Is this recommended for installing a new HB? Or has Bubba been here trying (in vain) to stop an oil leak?
I need to stop at AutoZone tomorrow for a new seal and fan belt, and would like to know if I should also get black RTV. Thanks in advance for your sage advice!
Very good job indeed, I'll be doing the same very soon, the only problem is I have a big block, so the working space will be much less!
) And in theory they could leak between the damper and the crank, just never heard of anyone doing this.
Another question - the Shop Manual indicates the HB bolt should be torqued to 60 ft-lbs. How do you keep the engine from turning to get the bolt tight enough?
Next time you swap the front seal, try this: use a nail to knock a small hole in the wide metal band of seal material. Thread a small machine screw into this hole (I use one with a hex head and use a 1/4" ratchet and socket) and use the screw as a grab or pry spot.
No sealant needed.
