powers steering leak
Old Apr 21, 2012 | 09:36 PM
johnnied's Avatar
johnnied
Default powers steering leak
all new, seems to be leaking at hose to control valve threads, and yes its tight. any fixes? and its leaking with out the engine running
Old Apr 22, 2012 | 07:58 AM
Jim Shea's Avatar
Jim Shea
The bosses on the control valve that is machined for the female hose ports have been know to crack if the hose nut is tightened too much. If it is cracked you probably will have to purchase a new control valve.
If the boss(es) on your control valve is not cracked, you may want to inspect inside the hose port. There should be a brass 45 degree seat that is pressed into the female port. You should see a circular indentation on the face of the brass seat from where the flare on the hose tubing was pressing evenly against the seat. If the circular pattern is interupted that could be the source of the leak.
Also inspect the face of the 45 degree flare on the hose tubing. The tubing could have a tiny crack.
The seal between the hose tubing and the brass seat is where they press together. No amount of teflon tape or caulk on the nut or tubing will prevent a fluid leak if that seal is not correct.
Jim
Old Apr 22, 2012 | 08:47 AM
themetalman03886's Avatar
themetalman03886
I had that exact same problem, I just got rid of power steering all together and just got a little MAN
Old Apr 22, 2012 | 08:58 AM
johnnied's Avatar
johnnied
thanks
To powers steering leak
