69 rear end suggestions
Old Apr 22, 2012 | 08:30 PM
Jerapais 69's Avatar
Jerapais 69
Default 69 rear end suggestions
I have an L36 with an M21 close ratio and a '63 3.70 rear end. What rear end would be the best compromise for highway cruising but some heat out of the hole? I would like to put a 69 rear send back in. Thx
Old Apr 22, 2012 | 08:53 PM
brando1118's Avatar
brando1118
I think you have the best compromise already, but that's me. A 3:55 would be the lowest I would go. Stick with your 63 rear end. They are more or less the same all the way to 79. There are differences in u-joint sizes and heavy duty inner axles and input shafts, but all 63-79 rear ends can be updated to any of the aforementioned combinations. Nowadays, it's a no-brainer to at least get the beefiest stuff GM provided, if not more beefier with aftermarket parts. Depends on your power output. Good Luck!
Old Apr 23, 2012 | 01:19 AM
OzzyTom's Avatar
OzzyTom
3.70 / 3.73 works very well for performance.
If you get concerned about highway cruising, look at putting in an overdrive gearbox.
Lots of choices now...
Old Apr 23, 2012 | 11:59 AM
Jerapais 69
Thanks all for the input. Really helps. J
Old Apr 23, 2012 | 01:17 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
A TKO trans. You get deeper first gear and O/D. Best of both worlds.
JIM
To 69 rear end suggestions
