Questions about getting a new cam
Old May 20, 2002 | 03:34 PM
theanswriz42's Avatar
theanswriz42
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
Default Questions about getting a new cam
I know i've been picking all your brains now that i have a running car. I'm wondering what would be a good cam for an L48? I've also been told i need to upgrade the valve springs as well? Would I be better off with roller rockers? More info would be greatly appreciated.
:cheers:
Old May 20, 2002 | 04:51 PM
Tom73's Avatar
Tom73
Default Re: Questions about getting a new cam (theanswriz42)
Call the cam compinies and talk with their customer service people. They can tell you exactly what you need based on what you have and what you want of of the car.
tom...
Old May 20, 2002 | 05:44 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: Questions about getting a new cam (Tom73)
The comp XE-262 is a good safe pick.
Old May 20, 2002 | 06:52 PM
terry82's Avatar
terry82
tom...
tell them what you want,they can help you.
Old May 20, 2002 | 07:01 PM
tnt76vette's Avatar
tnt76vette
Default Re: Questions about getting a new cam (terry82)
Some cams you HAVE to change the springs and some You dont...depending on Lift. Didnt have to on my 260H and after 5K miles all is well.....knock on wood..... :jester . Believe max lift w/stock springs is abt .460 or so :cheers:
Old May 20, 2002 | 07:07 PM
theanswriz42
Default Re: Questions about getting a new cam (tnt76vette)
I'm hoping I don't have to do it, otherwise it's going to be a pain in the butt and expensive. I don't want anything too radical, just something that'll make a difference in performance.
:cheers:
terryrudy's Avatar
terryrudy
I got the 268h cam and didn't have to change springs either. Though now I have the Alum heads on and they came with springs.
-terry
Old May 20, 2002 | 07:09 PM
theanswriz42
Default Re: Questions about getting a new cam (terryrudy)
What is the difference between the 260, 268 and 262?
Old May 20, 2002 | 07:10 PM
terryrudy's Avatar
terryrudy
not sure exactly. I think the 260 has more tq but 268 gives more hp. I could be wrong though. Hopefully someone more knowledgable will pipe in.
-terry
Old May 20, 2002 | 07:36 PM
Justin79-L-82's Avatar
Justin79-L-82
the 262 has more torque then the 268
Old May 20, 2002 | 09:33 PM
wes76's Avatar
wes76
I installed the 268h cam with a Edelbrock Performer intake, and used the old springs . So far so good, lots of power good performance, i'm thinking about new heads for next winter's project though... It just never ends... probably should just go for the zz4.
:crazy: :crazy:
Old May 20, 2002 | 09:58 PM
theanswriz42
Default Re: Questions about getting a new cam (wes76)
:crazy: :crazy:
:lol: that's exactly what i've been telling myself now that i'm $3300 into my car project. I could have picked up a ZZ4 from GM Parts Direct for $3500, ohh well. The 350 is a good block and I can always make it as powerful as a ZZ4 I bet.
:cheers:
Old May 20, 2002 | 11:13 PM
theanswriz42
tnt76vette - Where did you get your .460 cam from? and how did you select it?
Old May 21, 2002 | 01:44 AM
tnt76vette's Avatar
tnt76vette
Believe I said that abt .460 was max lift for stock springs. My CompCam 260H has a max lift of .440. It was recommended to me by Comp Cams w/a strong 2nd by Ganey, mostly because I have an Auto Trans. It pulls STRONG (compared to Stock) from a standing start, and is good out to 5K or so.....others will argue but I really dont see how ya need much more than that for the street....................... :D :D :D
Old May 21, 2002 | 05:10 AM
Rockn-Roll's Avatar
Rockn-Roll
I emailed CompCams and they sent me a recommendation for everything I need. I told them that I wanted the most horsepower from my L48 without sacraficing safety, and without causing it to idle rough. I was recommended the High Energy 268H or the Magnum 270H, and was told that I DO need to get new springs for either of these cams.
Here's is the thread where I posted it:
http://forums.corvetteforum.com/zerothread?id=286772
Goto CompCams at http://www.compcams.com and follow the link to online cam recommendations...it's a form that you fill out describing the engine and current cam and such, plus what you will be using it for.
Old May 21, 2002 | 09:33 AM
theanswriz42
Default Re: Questions about getting a new cam (Rockn-Roll)
Wow, thanks for the advice, I appreciate it.
:cheers:
To Questions about getting a new cam
