Rear Suspesion Question
Heres all the parts so you can see what they broke...
If the spring, bolt and TA broke in the manner you claim, the car would be sitting very low (collapsed suspension) on that side of the car. Is this the case?
To remove the Trailing arm..
The bolt securing the T/A to the frame use to rust and get stuck inside the T/A bushings and are therfore impossible to remove.
First take out the pin that holds the T/A shims in position, the work them up with a hammer and a chisel (correct word?) so you get access to the holes in the shims.
Then just pull the shims out.
OK it may take som force to get the shims out so this is how i have done it with sucess.
Yepp, its a bit "cavemen style"
but it works. Slack off the chain and then stroke hard, repeat and eventually the shims come out (picture below).
When the shims are removed use one of these saws (dont know the english name for it) and just cut the bolt and pull the T/A free.
Job done, now paint and rebuild with new parts.
Good luck.
//Ricky.
Welcome to the Forum and congratulations on your purchase. I have three '74s and have pulled the trailing arms on one of them recently. I agree with the above about the "slide hammer" to remove the shims, but you might not have to cut the TA bolt. Spray it liberally with PB Blaster or Penetrene etc. for a few days before removal.
If you can unscrew the nut from the bolt, then that's one piece you don't have to purchase. Now, as to the damage, it's only steel plate - it can be welded. Luckily you live in the US and it might very well be easier and cheaper to buy a good used TA, but once your damaged one is out, any competent weldor should be able to fix it up.
If you ever plan to put on wiiiiide wheels, then you should look at buying a new pair of offset TAs and save a whole lot of trouble. If you want to keep your existing TAs, then at least consider moving the parking brake bracket to the top of the TA. This will give you another inch of room if you fit wheels with a bigger backspacing.
Once your car is up in the air for the left TA, you would be wise to pull the other and have them both checked out by a competent Corvette repairer as NOW is the time to fix them if there is anything wrong with them.
Good luck with your project and please, consider removing those stripes across the rear end.
Regards from Down Under.
aussiejohn
