Figured out my voltage issue...
Old Apr 28, 2012 | 05:34 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Figured out my voltage issue...
I guess I threw the belt. lol. Almost bought a new alt and voltage regulator.
Old Apr 30, 2012 | 04:55 AM
lvmyvt76's Avatar
lvmyvt76
You thru the belt??
Old Apr 30, 2012 | 10:43 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Originally Posted by lvmyvt76
You thru the belt??
Yep, Apparently my accessories are only good to 6000 rpm. Ordering a deep groove pulley and a new alt.
Old May 10, 2012 | 07:12 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Changed out the alt with a new deep groove pulley. Now I'm 14V at idle. Looks like the alternator was bad also.
Old May 13, 2012 | 12:47 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default What's wrong with 14V?
You need 'bout 14V to charge. Make sure you have the alt tested first.
Something you should note is that a 12V lead acid batt is actually something 13.2V fully charged. So you need that 14V from the alt to force electrons back into the batt - need greater potential to make it charge. I wouldn't want much more than 14V though.
I have a cheap Hobo Fake batt tester that also measures voltage so i can see the voltage with engine on and off. I want to see at least another volt or more with the engine running to verify alt is pushing out current/electrons back to the batt.
Hope this helps and save u a few bucks,
cardo0
To Figured out my voltage issue...
