Changed temperature sensors yesterday...
Old May 20, 2002 | 09:41 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Changed temperature sensors yesterday...
Yesterday - when I fixed up my wipers - I also changed the temperature sensor. I was using a 68 Vette temperature sensor with the Autometer Phantom gauges (because I destroyed the sensor that came with the gauge).
I always thought that the readings with the 68 sensor were accurate... However - I was wrong. When showing 180 - the temperature was actually 165 and when showing 195 it was actually 180. I drove today through very heavy traffic and the temperature never went above 175 degrees (measured in the intake - which indicates a temperature of approx. 160 degrees in the heads... I think that I am running too cool.. I might change my thermostat. Currently I use a High Flow 160 degree thermostat. I might change it to a 180 degree thermostat...
:cheers:
Olivier
Old May 20, 2002 | 09:57 PM
7tea1's Avatar
7tea1
Default Re: Changed temperature sensors yesterday... (GrandSportC3)
Oliver,
I'm curious---what senser are you using now??
and how do you know if the current reading is accurate, or if the prior readings
were inaccurate :confused:
Old May 20, 2002 | 10:01 PM
69stingray's Avatar
69stingray
How well does those highlights work on that Grand Sport? They look GREAT!! :D
Old May 20, 2002 | 10:04 PM
GrandSportC3
Default Re: Changed temperature sensors yesterday... (7tea1)
Oliver,
I am using the correct sensor for the Autometer gauge. (I ordered it from SUMMIT). It is the 100% correct sensor!
:cheers:
Olivier
Old May 20, 2002 | 10:07 PM
GrandSportC3
Default Re: Changed temperature sensors yesterday... (69stingray)
They work excellent. There is not much difference to regular Vette headlights... Especially the High Beams are very strong!!! I actually have to adjust my headlights because I recently had the front end (including shocks and springs) rebuilt. This raised the front of my Vette by 1+ inch...
:cheers:
Olivier
Old May 20, 2002 | 10:28 PM
70 LS1's Avatar
70 LS1
Was the autometer sensor the same size as the 68? The reason I ask is I need to find a sensor that is much smaller than the 70 one to fit the LS-1 heads. I don't mind drilling out the hole a little, but I don't want to double its size.
Old May 20, 2002 | 10:31 PM
GrandSportC3
Default Re: Changed temperature sensors yesterday... (70 LS1)
The sensor itself is very small. It comes with two adapters to fit almost any application!
:cheers:
Olivier
[Modified by GrandSportC3, 9:31 PM 5/20/2002]
Old May 20, 2002 | 10:36 PM
GrandSportC3
The part number is ATM-2258!!!
:cheers:
Olivier
[Modified by GrandSportC3, 9:39 PM 5/20/2002]
Old May 20, 2002 | 10:39 PM
70 LS1's Avatar
70 LS1
Thanks, Olivier
Old May 20, 2002 | 10:40 PM
GrandSportC3
Thanks, Olivier
anytime!!! :cheers: :cheers: :cheers:
BTW- just added a pic of the sensor to previous posting
[Modified by GrandSportC3, 9:41 PM 5/20/2002]
To Changed temperature sensors yesterday...
