Front sway bar
Old Apr 30, 2012 | 02:24 PM
raceman1's Avatar
raceman1
Cruising
Default Front sway bar
Im not sure what is upside on the sway bar Can you give me some advice before I install it upside down
Old Apr 30, 2012 | 02:47 PM
MelWff's Avatar
MelWff
Look at the image in this article the end is slightly bent up
http://www.corvettemagazine.com/susp...n-rebuild.html
Old Apr 30, 2012 | 06:04 PM
Mgrad92's Avatar
Mgrad92
I screwed it up myself. Unfortunately it will bolt up upsidedown. The dead giveaway is the slight curve. Install it so you have more clearance as opposed to less.
Old Apr 30, 2012 | 06:49 PM
Mgrad92's Avatar
Mgrad92
Just re-read that response, and it may not make sense intil after you've done it. Let me say if you bolt it up both ways at the bushings, one way will definitely look easier than the other in terms of bolting up the end links. The easier one is the right one.
To Front sway bar
