Fuel pump for BB?
Old May 21, 2002 | 09:00 AM
467-Ratman's Avatar
467-Ratman
Default Fuel pump for BB?
I put a chrome Holley fuel pump on my BB and now have noticed that it does not seem to work with the extra fuel vapor line. When I hooked it up I had no fuel pressure and it just returned the fuel to the tank via the vapor line.Do I need to have the vapor line hooked up? What is the purpose of it? When we ran the engine outside of the car I did not have the vapor line installed. My old 350 motor had a GM fuel pump and used both the main fuel line and the return vapor line. Thanks for the help, should I get the GM pump? :confused: :confused:
Old May 21, 2002 | 01:03 PM
Todbo's Avatar
Todbo
Default Re: Fuel pump for BB? (467-Ratman)
same problem, most people said to leave it unpluged , i've thinking about covering it , maybe with some mesh. stick with the holley
Old May 21, 2002 | 05:55 PM
467-Ratman's Avatar
467-Ratman
Default Re: Fuel pump for BB? (Todbo)
Do you really need the fuel going back to the tank to cool down? Somone told me thats why there are two lines. Also they mentioned something about the system being pressurized? :confused:
Old May 21, 2002 | 09:49 PM
Terrys69coupe's Avatar
Terrys69coupe
Hi Tom plug the return line and run the holley no problems with out it .Did it on my 68 and dads 69. Also did it on a 4wd S-10 that i v-8ed. no ill effects. :chevy
Old May 21, 2002 | 10:43 PM
467-Ratman's Avatar
467-Ratman
Default Re: Fuel pump for BB? (Terrys69coupe)
Terry, Thanks for the info, I will be keeping the Holley pump for sure. I can't believe how loud it was inside the car without the pipes hooked up!!! I was going to take it on Friday to have new pipes connected to the headers, but I think I will do some cruzing this weekend , watch out , it might break some windows!!
To Fuel pump for BB?
