THROTTLE CABLE BRACKET
Old May 21, 2002 | 10:57 AM
Ken74Conv's Avatar
Ken74Conv
Default THROTTLE CABLE BRACKET
I am installing my ZZ4 with a Holley Avenger on it. What are you guys using for a throttle cable bracket when you convert to the Holley setup?
Its a 4 speed so there is no transmission linkage.
Old May 21, 2002 | 11:50 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: THROTTLE CABLE BRACKET (Ken74Conv)
Go to www.summitracing.com search for part number CSI-630B
and buy one of these
They ROCK!
Old May 21, 2002 | 12:14 PM
69ttop502's Avatar
69ttop502
Default Re: THROTTLE CABLE BRACKET (427V8)
Hey Keith do you know if that would work on a big block with a 2 inch drop base. Am looking for something to work and all the Holley bracketsx from places like paragon have been unavailable. Thanks, Bill.
Old May 21, 2002 | 12:30 PM
427V8's Avatar
427V8
Default Re: THROTTLE CABLE BRACKET (69ttop502)
I have a drop base on mine and it's pretty close ( like 1/8"). I don't remember tho if it's a 1.5" or 2" drop...
Oh and it's just the adjustable cable mount that hits so I'm SURE you could make it work if you can pull the cable mount back out from under the carb.
Old May 21, 2002 | 12:39 PM
Todbo's Avatar
Todbo
427v8 what kind of holding nut is on your cable , my 71 has the small round style , all I can find locally is the linkage that holds the square clip in style throttle cable.
Old May 21, 2002 | 12:50 PM
427V8's Avatar
427V8
Default Re: THROTTLE CABLE BRACKET (Todbo)
I could only find the 'morse' type too ( with the square hole ) but it works anyway.
I'm using a Lokar cable that has a threaded end that goes into the bracket, two washers and a Nut hold it all on..
Old May 21, 2002 | 01:38 PM
Todbo's Avatar
Todbo
thanks , I may try to fab something up
Old May 21, 2002 | 02:04 PM
Ken74Conv's Avatar
Ken74Conv
That looks good. It's out of stock at Summit so I guess I'll try Jegs.
Thanks for the help!
To THROTTLE CABLE BRACKET
