75 heater trouble shooting
Old May 7, 2012 | 09:21 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Default 75 heater trouble shooting
Is there a trouble shooting/diagnostic guide for heat/air for a 75, the heater works but i don't feel the heat coming out of the vents i select, same for the air.
The car heats but i think its only coming from the floor vents, i don't think the top dash vents are working. With air on it does seem like the dash vents do work.
If i just put it on vent nothing is happening.
After owning the car for 37 years you would think i would have figured it out by now.
Any guidance would be appreciated
Old May 7, 2012 | 11:25 PM
lvmyvt76's Avatar
lvmyvt76
Its probably a vacuum problem with the heater/ac control system in the console, OR, the vacuum moduals are out that change the venting behind the dash. Maybe Willcox Corvette has something on this?? in their service help.
Old May 8, 2012 | 12:20 PM
JGreen's Avatar
JGreen
I am in the process of rebuilding mine right now. When I pulled it apart, there was a nest so large in the main heater box that the actuator could not open/close. I pulled out what looked like a basketball made of carpet insulation, walnut shells and little brown sprinkles...and voila...it works again.
Old May 8, 2012 | 01:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you have the assembly instruction manual (AIM)? The AIM has a couple of pages on HVAC diagnostics. Sounds like your selector door is not moving and is not allowing changes to the air flow (floor to defrost, floor to vents, etc.)
Old May 8, 2012 | 10:14 PM
Mod75's Avatar
Mod75
Just got my AIM from the garage, will check it out.
Thanks to all for the input
To 75 heater trouble shooting
