Steering column
Old May 9, 2012 | 03:42 PM
bballron's Avatar
bballron
Cruising
Default Steering column
Took apart the steering column the other day on my 77 and noticed some bits and pieces of plastic had fallen out. I believe it used to be the horn contact retainer snap ring (with insulator). It is round with five ears or tabs sticking out. I have a new one on order but have no idea where it goes. Can someone help.
Thanks!
Old May 9, 2012 | 03:54 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Run a search for the link to Jim Shea's papers.
Old May 9, 2012 | 04:35 PM
TimAT's Avatar
TimAT
Jim Shea's papers on steering are the best there is.
That plastic piece is the insulator for the horn contact spring. Common for them to break and/or fall apart.
Old May 10, 2012 | 10:03 AM
bballron's Avatar
bballron
Cruising
I can't seem to find a diagram anywhere showing the location of this part.
Old May 10, 2012 | 10:43 AM
Scott Marzahl's Avatar
Scott Marzahl
Its the horn insulator. Here are all of Jim's papers, go to the illustratated parts.
http://jimshea.corvettefaq.com/?cat=5
Old May 10, 2012 | 11:44 PM
bballron's Avatar
bballron
Cruising
Default steering column
Thanks for help. Haven't found the part in question on a pic yet but I will keep looking.
Old May 11, 2012 | 12:01 AM
bballron's Avatar
bballron
Cruising
Haven't found insulator on any pic yet but I am assuming it goes above or beneath large spring located below steering wheel. ThANKS FOR HELP.
Old May 11, 2012 | 09:51 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I think this is what you are after..
http://willcoxcorvette.com/product_i...ducts_id=24018
Even the note on the sight tells the story.... Horn Contact Lower Plastic Retainer. 1970-1989 All. Five finger plastic contact insulator that breaks everytime you take the column apart
Old May 11, 2012 | 11:21 PM
dobroman2001's Avatar
dobroman2001
Thanks!
These Links should help out:
http://forums.corvetteforum.com/c3-t...-included.html
http://s189.photobucket.com/albums/z...eel%20removal/
To Steering column
