Recharge 1982 AC with 134a?
Received 1,469 Likes
Cruise-In II Veteran
It is against the law to vent R12 into the atmosphere and against the law to piddle with automotive AC systems unless you are a certified automotive HVAC technician. Any competent automotive AC shop can make this swap for you, do it right, and do it legally.
Pay the pros for this chore.
when switching from R12 to 134, the system needs to be completely flushed. The primary reason, is that a different oil type is used with r12 than 134,and they are not compatible. A professional will change out all of the O-rings in the system when doing the conversion. Old hoses can be used, but manufacturers use a different and heavier gauge material for hoses on OEM 134 systems.
Other than the legal issues of handling r12, these are all things you could do, but as Easy Mike said get it done right by a pro. For one thing, you won't have to pay to do it twice.
Find and repair your leak and stick with the good old R12 that originally came with the car. You will be much happier with the R12. I have no trouble finding it on craigslist every day for average of $20 dollars per can
Every 2 or 3 years I pay $70 for R12 plus labor to recharge a/c. Not that expensive.
St. Jude Donor '08
Do it once, and do it right. Take it to a A/C tech. and let him know exactly what you want to do, let him thoroughly flush the whole system to remove all the R-12 oil, replace all the O-rings with a R-134a compliant rings, put the correct oil, and take a vacuum for 20 min. or so before charging it with the R134a. If you can replace the condenser with a parallel flow one, do it, its MUCH better to have it in a R-134a system.
condenser
you get about 33% more efficiency with the newer condensers. do a search. lots of info on the cond. swap just within the last year. well worth the effort. lonebull
