Oh no, headlight issue
Old May 10, 2012 | 10:03 PM
ATIS's Avatar
ATIS
Default Oh no, headlight issue
My 75 headlights will open and close using the under dash valve, however I get no action from the head light switch (other then the lights coming on and being aimed at the ground under the car).
I looked at the vac diagram and I believe that means I have a bad head light switch... do you agree or should I look else where?
Old May 10, 2012 | 10:42 PM
GOLF72's Avatar
GOLF72
I am brand new to the board and C3 owner. Been working on cars for a long while and if I had those symptoms, the swtich would be the first think I would look to replace. I am sure a seasoned owner can give more sound advise.
Old May 11, 2012 | 02:05 AM
scottyp99's Avatar
scottyp99
http://forums.corvetteforum.com/c3-t...tem-works.html
It's a good thread on how you headlights work and how to figure out why they're not worling correctly.
Keep the shiny side up!
Scott
Old May 11, 2012 | 11:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Switch or possibly a loose vacuum hose on the switch.
To Oh no, headlight issue
