Re: Question? Is the 454 a stroked 427 (Glasman66)
The reason for less displacement...
I have read and have talked to engine builders that the 454 loses some of it's rev pushing that extra stroke. The 427 would rev to the moon. That is what makes the 427 L88 so leathal.
I'm either gonna build the poo out of a small block, or make a 427 rev monster.
Look at the Mallet web site. They are not making 454, but the 427. And might I add for 32 grand.
True, a 454 is more iron to sling than a 427, but look at NHRA dragsters they are running 502 cubic inch motors. Their limit is 505ci, believe me they would be a hell of a lot more cubes if there was no limit.
My dad builds air-boat motors that turn 6000rpms+ ALL day long, they're ALL 454ci+ motors.
I built my 468 to handle 7,000rpms+ with no problems.
IN THEORY, a smaller displacement, big-bore, short-stroke motor will produce more peak horsepower than a larger motor with the same bore and a larger stroke.
IN THEORY. In practice, the stroker motor should produce more horsepwoer and torque at low RPMS. The smaller motor may never get to rev high enough to utilize the theoretically available power, before camshafts, valvesprings, etc. intervene.
This is the real advantage of a 383 or other stroker: they produce horsepower at real-world RPMs.
Oh sure now you're gonna bring theory into it. I was just wondering. This all goes back to bench racing with my buds. I heard the 327 is the same. In truth, when I take the plunge I will either build the stroker 383 or an LT1 knockoff, only leaving the solid lifters out.
A LT1 roller motor would be sweet. But man those big block give me a hard.... :crazy:
Re: Question? Is the 454 a stroked 427 (fontking1a)
I thought the 454s had thinner water jackets and were prone to over heat because of this. Is that wrong?
No, 427 and 454 share the same block.
I've heard the overheating thing regarding motors with siamesed blocks (no water jacket between the cylinders) like the 400 SBC and 502 BBC, but I'm sure how much of it is fact.
The answer to both questions is yes, but bear in mind that it's an awfully expensive and time consuming way to lose power! If you want to rev at the expense of torque, go for a small block, maybe a 265 dual quad solid lifter motor, a 283-270hp, or even a 302 Z-28 motor. They'll rev 'til there's no tommorrow, and produce a push in your back above 3000 rpm that you wouldnt believe! But you gotta give up something to get something, and what you give up for that 5-6000 rpm peak power is low rpm driveability - you know, the stuff you use 99.9% of the time!
I'm in a perfect position to comment on this. The engine in the BOSS 302 is an amazing high RPM engine, yet it behaves like a 2 stroke dirt bike, with nothing off idle, then hang on when it hits 3000 RPM! The BB in the vette is all in when you start off, but runs out of breath and the ability to hang together at the top end. I imagine it's similar with the difference between the 427 and 454, although to a lesser degree. Each type is fun.
