rear rotor problem
Old May 11, 2012 | 07:38 PM
Pelayo114's Avatar
Pelayo114
Default rear rotor problem
I want to take off my rear rotors to check and adjust my parking brake and change the wheel bearings. Problem is that I can't get the rotor off. I saw an article by zip on how to do it. I drilled out the 5 rivet heads. I just didn't have a punch thats big enough for this application. Anyone know any other way I can get the rotor off to get access to the parking brake?
Old May 11, 2012 | 08:18 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
If you drilled/chisled off the tops of the rivets, the next step is to bring to bear vigorously with a BFH in such a way as to coerce its release.
That should do it.
Old May 11, 2012 | 09:04 PM
LongIsland C3's Avatar
LongIsland C3
Just went through it this past weekend. BFH only worked on one side. i then took a 18" piece of 2x4, cut it into a pair of wedges, drove the wedge down between the caliper mount and rotor. Tapped the studs a few times with a dead blow hammer and off she came. Hid the other wedge from my wife to prevent her from driving it through my heart. (She just found out I ordered a COMPLETE new interior,carpets,dash, seats, door panels etc.) If I stop posting suddenly, it was her!,it was her!
Old May 11, 2012 | 09:26 PM
Peterbuilt's Avatar
Peterbuilt
Did you try backing off the parking brake adjuster and spraying some penetrating oil on the rivet holes around the center of the rotor?
That might help.
Old May 11, 2012 | 09:48 PM
Pelayo114's Avatar
Pelayo114
Tried the hammer. No luck.
Ima try that 2x4 thing hopefully this weekend.
Parking brake is off since it hasn't been working for the longest. I've sprayed WD-40 into the holes.
Old May 12, 2012 | 11:44 AM
RobbSalzmann
St. Jude Donor '12
Apply leverge with a big prybar while beating with the BFH. Replacement rotors are cheap, much cheaper than your time here. Good luck and let us know how it oges
Old May 13, 2012 | 11:09 AM
69 Chevy's Avatar
69 Chevy
I want to take off my rear rotors to check and adjust my parking brake and change the wheel bearings. Problem is that I can't get the rotor off. I just didn't have a punch thats big enough for this application.
If you don't have a lousy punch big enough for the rivets, what makes you think you can replace the wheel bearings without all the specialized tools that job requires?
Old May 13, 2012 | 11:19 AM
Mike Ward's Avatar
Mike Ward
If you've been beating on it that hard with a hammer, "Ima" bet the wheel bearings are scrap now too.
Old May 15, 2012 | 03:08 PM
Pelayo114's Avatar
Pelayo114
I was working all weekend. Couldn't get to work on the car till now. But good news! Finally got them off. Everyday this weekend I would spray some wd-40 around the rotors. Today with light hammer tapping and pulling on the rotor they came right off. I wish it would've been this easy from the start lol now I'm trying to get at the wheel bearings. My parking brake had a lot of broken parts. Parts that look like they broke a long time ago.
Old May 15, 2012 | 04:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by LongIsland C3
...Hid the other wedge from my wife to prevent her from driving it through my heart. (She just found out I ordered a COMPLETE new interior,carpets,dash, seats, door panels etc.) If I stop posting suddenly, it was her!,it was her!...
Psssst. She knows where you hid it.
Old May 15, 2012 | 04:22 PM
Pelayo114's Avatar
Pelayo114
For the rear wheel bearings and things related, would you guys recommend just trying a DIY job here or sending the entire assembly out to be rebuilt? I've been getting different opinions from family and friends but I want to hear from the guys who have been through this and have experience with all this.
Old May 15, 2012 | 06:45 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Old May 15, 2012 | 06:52 PM
...Roger...'s Avatar
...Roger...
Send it out. Its not easy and you need special tools.
Old May 15, 2012 | 07:21 PM
Pelayo114's Avatar
Pelayo114
On a scale of 1-10 how difficult would you rate it? 10 being like near impossible.
And what do you mean by special tools? I might be able to borrow some from my uncle depending on what I'd need.
Old May 15, 2012 | 07:44 PM
Mike Ward's Avatar
Mike Ward
It's not just having tools- it's the skill in using them.
Old May 15, 2012 | 07:55 PM
Clams Canino's Avatar
Clams Canino
Corvette rear wheel bearing setup tools - very specific.
And a hydraulic press too.
Trust me, send them out.
On a scale of 1-10, they are an 8-9 - really.
-W
Old May 15, 2012 | 10:06 PM
...Roger...
with the above comments.
Even if you are skilled , the first time will be tough and you take the chance of damaging something costly. If you want to learn,that's fine then rent buy or rent the tools and we can direct you to instructions but if you just want the job done and done right then you will be money ahead to send them to a good re-builder.
Old May 16, 2012 | 12:32 AM
Pelayo114's Avatar
Pelayo114
I'm thinking of sending them out instead. I was looking through that thread you showed me roger. It actually looks like something I'd like to learn. But something I don't want to make a mistake on and damage something costly. I'll take the advice and send them out. You guys have any recommendations on where I should send em to? I was looking at Vansteel but I'm open to any suggestions. I want this done right at the best possible price.
To rear rotor problem
