Differential Oil Replacement
Old May 14, 2012 | 10:14 PM
ATIS's Avatar
ATIS
I just drained and replaced my fluid in the 75. I used Royal Purple 75-90 syn with posi additive already in it. No issues, nice and quiet.
Old May 15, 2012 | 04:11 AM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
Originally Posted by Bond007
What are the correct names for the GM oil products for:
Manual Transmission
Differential
Additive
Axle Lubricant GM Part # 89021671 - Two required
Limited Slip Axle Lubricant Additive - GM Part # 1052358 - One required
Old May 15, 2012 | 12:45 PM
Bond007's Avatar
Bond007
Default Oil
Thanks Everyone
Old May 15, 2012 | 01:16 PM
Clams Canino's Avatar
Clams Canino
Same here.
Noting louder that you DON'T use the additive in Royal Purple.
-W
Old May 16, 2012 | 10:12 AM
jim2527's Avatar
jim2527
When I did mine I drained, refilled, drove a few miles, drained again and then refilled. You'd be amazed at how dirty the second drain is.
Old May 16, 2012 | 10:26 AM
Clams Canino
I had the cover off mine - cleaned it pretty well inside before refilling.
-W
Old May 21, 2012 | 02:05 PM
DanielA's Avatar
DanielA
I need to add some posi conditioner to my differential. I had the car up on ramps last weekend. It is pretty easy to touch the fill plug, but how can you get a wrench on it? It is a square nut and there does not look to be any room to swing a crescent wrench.
There must be an easy way to do this. Could comeone clue me in?
Old May 21, 2012 | 02:14 PM
Clams Canino
You can us a 4pt or 8pt socket easily enough. Or if lucky you can break it free with a crescent and turn it out by hand. I believe it might have a little taper to it.
-W
Old May 23, 2012 | 07:11 PM
travelerbob's Avatar
travelerbob
Default Diff oil removal
Hello Fellow Vetteheads,
While replacing tank etc checked the oil in the differential and noticed it to be very black...how does one get it out ..should it be warm?..what oil and additive do I use to replace?
Thank You in Advance.
I'm not sure whitch co. offers it but there is a kit to add a drain plug to the diff. Template shows where to drill and supplies the drill / tap and plug. Price reasonable. May have to Google it. Sounds better than the sucko job.
Old May 24, 2012 | 01:06 PM
Super6's Avatar
Super6
When you add these, make sure you put the Limit Slip Axle Lube additive in first. This way the whole contents get in the differential. If you do it the other way around, adding the additive last, the fluid starts to overflow out the opening before all of the additive is in the diff.
The well-known gentlemen from Connecticut, who is one of the premier rebuilders of rears, steering boxes and trailing arms, recommends the GM fluids over the synthetic stuff. FWIW.
Old May 25, 2012 | 12:16 AM
Ralphbf's Avatar
Ralphbf
I am a big fan of synthetic oil and grease.
I used conventional oil and GM limited slip treatment.
Ralph
Old Jul 18, 2012 | 01:21 PM
C3 Vette Dude's Avatar
C3 Vette Dude
What is the wait of the GM fluid and cann it be purchased from a local autoparts store like Autozone?
Old Jul 18, 2012 | 02:15 PM
  #33
Clams Canino
Chevy parts counter.
-W
Old Jul 18, 2012 | 02:40 PM
  #34
Ralphbf's Avatar
Ralphbf
If the question is "What is the weight of the oil for the rear end ",it's 75/90.
And it's available most any where. The additive is about $10.00 at the dealership.
It should take almost 2 quarts. The additive is 4 ounces.
Ralph
Old Jul 18, 2012 | 03:00 PM
  #35
C3 Vette Dude
Default rear end lude
Ralph
Thanks Ralph. Can it be changed without lifting the car. Can I change it in my garage laying on my back or is it to low to the ground.
Old Jul 18, 2012 | 03:12 PM
  #36
Ralphbf's Avatar
Ralphbf
You have to get under the car some how.
I like using ramps they are fast, easy and safe.
You will need a 5/8 8 point or 12 point socket, 4 inch extension and a ratchet.
Plug in it the top right rear of the differential.
And you will have to suck out the old stuff and pump in the new.
Some remove the cover, clean out the crud, replace gasket and reinstall the ten bolt cover. No sucking involved that way.
Ralph
Old Jul 18, 2012 | 03:34 PM
  #37
C3 Vette Dude
Ralph
Thanks again! How did you get that picture of your car on the post?
To Differential Oil Replacement
Old Jul 18, 2012 | 03:43 PM
  #38
Ralphbf's Avatar
Ralphbf
Honestly I fumbled through. It was on my 3rd attempt, and I can't really remember.
R~
Old Oct 2, 2012 | 06:10 PM
  #39
bouvie1's Avatar
bouvie1
Originally Posted by gcusmano74
Another place to put the drain plug is under the bracket that holds the strut rods. Drill and tap 1/4" NPT just far enough to one side that you miss the ring gear. Make the hole on the bracket larger, of course, so you can easily insert/remove the plug..
My question is where do you siphon/fill GM lub/additive. Any pics or location will be appreciated. Thanks bouvie1
Old Oct 3, 2012 | 02:25 AM
  #40
Ralphbf's Avatar
Ralphbf
Passenger side, top rear, there is a plug.
Suck it out and fill through the plug hole.
R~
