1973 wheel bearing issue?
I just purchased a '73 roadster and I'm getting a little whump, whump noise from the left rear. I've checked the wheel, and I'm getting some play at the 12 o'clock and 6 o'clock positions, but not any at 3 and 6 o'clock. Right rear appears good and snug.
Is this a wheel bearing issue or something else in the control arm assembly? I did a little digging and don't really see where the movement could be coming from.
A little history on the car: over 120k miles, stored winters in MI, driven hard in the 70's (car was NCCC race winner multiple times). Hasn't been driven much in the last 5-10 years. I'm the second owner and have known the owner since the late 70's. Most issues were dealt with.
I'm in the process of changing fluids (oil, ps, coolant, brake bleed, etc.). Didn't realize there were so many lube points on the suspension!
Thanks for any and all replies.
GRAPIDSSTEVE
If the entire arm is moving then could be your shims rusted/worn out or the bushing is bad. If its just the studs/hub then probably need to have the trailing arm rebuilt.
Welcome to the 73 "middle child" Corvette Club.
Of course I had thought it was the bearing so I changed those. It was probably the tire that caused the bearing to wear faster.
Anyway, if you can move the wheel while standing under it you will definitely see if it is the bearing. The spindle will move within the trailing arm and it is very noticeable.
I did have the wheel off and I was able to get a little play in the rotor assembly.
My inclination is to do a rear end job on this thing and be done with it. Take it all the way down to the differential, rebuild the trailing arms, and new u-joints and bushings all the way around. I did that on the '85 and liked the results. Just don't like the down-time it takes to do it.
Thanks for the replies!
The whump whump you describe might just be a bad u-joint. The play at 6-12 o'clock is very common, probably more that half the C3s on the road have some- the sky is not falling and that's not the source of the noise anyway. If there's no play at 3-9 o'clock then it's probably not the wheel bearing.
BTW- there are no lube points on C3 rear suspension, unless somebody has substituted aftermarket stuff.
