Lets talk about electric fan control
I want to drive the beast a little this year,..even if I have to resort to a toggle switch and relay......
I ended up ordering the DCC FK-55 ,...Brian said three weeks,...so I might get a head start routing the fan wiring.
I'm thinking of hiding the controller under the storage compartment behind the passanger seat, and routing wires to the fan/sender. That way it's a short hop to the battery for the controller, and all the electronics stays high and dry.
I like the idea of speed control because it gradually comes on, as the temps rise. The relay controls are all or nothing,...so you sit at a stop light watching the temps climb to super hot,...then the fan kicks in.
The truck was a round town, stop & go, short hopp daily driver.
Also the Viper powered dodge trucks use PWM to actuate the solenoid that operated the hydraulically driven fan.
I dont think your statement of PWM killing batteries has any merit
The PWM lets the semiconductor in the controller buffer the in rush current the fan motor would have on start, and limit the current it draws based on actual thermal requirements,...Translation. It doesn't have to run full blast to keep the temperature constant in the radiator. Fan runs quiter most of the time, using less power than otherwise would be used. The temps are kept in check closer to the set point by running the fan slower, and prior to the set point, building speed as needed,so the need for a fan running at full speed is reduced....
The relay version waits till the set point, and runs full speed ahead to try and prevent the over heated radiator from boiling over.
I suppose that if the cooling system is up to it,...either would work just fine.
All of these different ways of turning the fan on work, the makers of the VSC's say the temp.sw. and relay are old tech, the old tech. guys say the VSC's are wasted tech. I spent 3 monthe researching and trying different systems on my C4. it's just a personal choice. one last bit of advice, dont just read the testimonials, read the complaint posts also and not just on this site, make your own decision.
The two vehicles you running it on above, I know nothing of the wiring on them....so NO comment, the case in point concerns the C3, and the typical C3 has a 8-10 ga wire going to the starter battery terminal from the alt output stud....BUT, here is the critical thing....in that wiring is a ~12 ga fusible link, done to keep the car from burning, should something Cat *** trophic happen, from failures to wrecks....the battery circuit opens to the car, so the damn battery don't blow up....much less fry the heavy battery cables....
now here is the rub....and I have proven it on my '72 vette....run a heavy fan off the battery directly, and watch the voltage, it goes from 14.8 to 13.3 when properly running, depending on the charge the battery needs....but if the charging voltage is dropped something like 1.5+ volts at the battery, the car never knows, and so the battery never sees full recharge....how long you can leave it that way is anyone's guess.....DCC /Brian insisted on running another jumper from alt stud to the battery, I forget the gauge of wire, I suggested a fuse/breaker, for it, at minimum.....he objected, I quit the thread....
BTW- The Lincoln fan is excellent for moving lots of air (prior project).
Get the brass adaptor and install your switch.
The Spal was not user friendly
The DCC worked fine for what it was, however the temp probe failed at the point where it attaches to the controller it self! The type of connector they used for the probe is crap!
The relays work as intended!
