Anyone Use Mass Flo EFI?
Did you go through the effort of wideband tuning your VE table?
I'll chime in here to keep the thread at the top until Gordonm sees this and responds. I have both his old Gen1 motor and his Mass Flo fuel injection system that he sold me last fall before he went LS. I'm just a week or so out from my first test drive after a TON of work battling a disease called, "whilyeratititis". What I can tell you is that he had the same issues with funny idle that he solved by having a custom ground cam made by Comp Cams. I don't have the specs handy, but it's a pretty healthy cam. I can tell you that the Mass Flo is a top quality kit with a very nice wiring harness and very accurate and descriptive instructions. I also believe that Mass Flo additionally offered to re-program the ECU to alleviate the driveability issues, but Gordon went with the custom cam. He can elaborate more when he responds. I've fired up the motor a couple of times to test that all sensors are functioning and that the ECU is happy. Fired right up with no issues once I finally got things sorted. I don't think you will be disappointed with the Mass Flo kit at all. Gordonm heavily documented his build of this engine and the installation of the Mass Flo kit here on the forum. Just search his user name with threads initiated by him. Go back a bit and you will see a ton of info that can answer your questions.
Good luck!
By "most people" I meant "most people", that is, tuners and other experienced engine builders. Getting a MAP system configured correctly requires a little more initial time investment than MAF, but once it's dialed in it should last until you make a significant change to your engine.
MAF systems should require the same amount of tuning, the idea there is that once you've dialed in the MAF it shouldn't require any changes. "Tuning" a MAF is basically calibrating the transfer function. Tuning VE requires new effort after a change because it's based on volumetric efficiency estimates. If those are off, your car won't run right.
The reason I bring it up, is if you're having problems getting your car to run in MAP mode, the odds are high (potentially higher) that you'll have problems getting it to run with a MAF setup.
Of course, if the particular system you were using just didn't cut mustard, that's a different story.
The LS series of computers offer great control, by the way, and I don't see why one would want to replace them with something aftermarket for the large majority of engines out there. I've spent some time calibrating them and once you figure out what all the tables mean and how they related, they work great.
That's what I'd recommend if you're going with an LS build. I'm friends with a local tuner who runs 1000+rwhp cars on OEM ECMs. From there, you can choose to go MAP, MAF, or MAP+MAF. (I tune my ECMS in MAP only, then MAF only, then let them run in MAP+MAF)
Would have been interesting to see what was going on with a datalogger. Make sure MASSFlo has good datalogging functionality or you'll be in the same boat.
A big issue can be injector constants - if they're messed up you can chase the MAF transfer function or the MAP VE tables all day long and never get it to run right.
I definitely prefer EFI to carb, but I'm going to mess with the Q-Jet on my 78 so that I can say that I did!
The motor is a 454 small block (400 block) dynoed (using the MassFlo) at 572 h.p. and 585 ft./lbs. with a custom grind Comp Cams roller.
The MassFlo system is well built and laid out and controls lots of functions. Very plug & play. In the next week or so, the car will be out on the road being driven and I can give a better assessment then. So far so good though.......
Yes you set the timing for if I remember correctly about 12 degrees with it unplugged. Once this is set you plug it back in and the computer takes care of all timing.
Example - http://www.youtube.com/watch?v= RXHzMHmYrQs (Not my vid, just a random engine start)
You'll see the "http://www.youtube.com/watch?v=", you want to wrap just the sequence after the "v=". So it will look like this (without the spaces) [ YT ] RXHzMHmYrQs [ /YT ]
put in a stock L98 cam, and engine is fine now, nice calm idle runs fine....
I"m in Orange Park, pm if you want to get together some time, I"m retarred so anytime is fine....
