c3 road race build
Old May 16, 2012 | 11:12 PM
powersauto's Avatar
powersauto
Default c3 road race build
Hello my car Is gonna be for nasa super unlimited
it's a 80 that I've made a roadster I have built every part of this car and still have a ways to go the motor is an late 80's le mans prototype chevy 4.5l 282ci. trans is a t56 thanks for looking this is it so far......
Old May 16, 2012 | 11:42 PM
ramair_bryan's Avatar
ramair_bryan
0ooooooooooooooooooo........ God I love road race stuff.
Old May 17, 2012 | 12:36 AM
gkull's Avatar
gkull
Are you going for the 8.7 pounds per hp more like ST2? I was looking at your cage. C-3's are tiny inside. The door bars need to be out inside the outer door skin. So you make the doors hollow with no inner panel. Road racing seats are big. Our shop has a few road racing Vettes and my 79 is caged.
The NASA rules allow unlimited stiffening. So you can make a 10 - 12 -14 point cage. I've done some NASA ST1 events
My advice is coil overs and big brakes with air ducting.
Old May 17, 2012 | 08:15 AM
gkull's Avatar
gkull
I was trying to find info on your le mans prototype chevy 4.5l 282ci.
I couldn't find anything. NASA uses engine dyno's to level the playing field. If it was me............. I'd be running the biggest ci for TQ and make it low in HP to meet the weight class
Old May 17, 2012 | 08:46 AM
powersauto's Avatar
powersauto
I'll be shooting for st1 my car weight is very low in full race trim it should be around 2000lbs the power of the engine is 550 @ 7500 the specs are 4.155 bore 6" rod 348 stroke v6 13.3 to1 gm heads with allot of work solid roller with 670 lift and a gm cross ram intake there are not allot of motors like this out there but there are allot of the Buick engines and this is a Chevy copy
http://www.race-cars.com/engsales/ot...99161666ss.htm
As far as brakes I have a wilwood set up there will be cooling ducts and I'll be running a quick change with a double a arm set up and a cantilever suspension
Old May 17, 2012 | 05:32 PM
gkull's Avatar
gkull
2000 is tough figure to get to. Interesting engine. I would still build a 434 small block and make 550 hp with nearly 600 foot pounds of TQ
Old May 17, 2012 | 07:13 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Subscribed.
Old May 17, 2012 | 09:26 PM
powersauto's Avatar
powersauto
I understand where your comming from with the 434 that would be a great motor but what I would gain in tq I would be adding in lbs I'm in the high 400s in tq but around 160lbs lighter witch will help in the handling plus this engine is what I have and a 434 is big$$$$$
Old May 18, 2012 | 12:46 AM
gkull's Avatar
gkull
I was trying to dig for info on him. He used to be on this forum and won the west coast championship in NASA st1 he bought a "BadAss" motor 434 ci 675 hp he had the lap record at infinion race way. anyway he gave up on his vette after a couple of years and went class racing in a Mustang
The motors are only like $13K and the aluminum Dart blocks are only $3000 more. His race weight more like wet 2850 with driver
Old May 18, 2012 | 10:53 PM
powersauto's Avatar
powersauto
I got a little finish welding done tonight
Old May 18, 2012 | 11:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
holy carp are those some nice welds. Wow.
Old May 19, 2012 | 12:01 AM
Crepitus's Avatar
Crepitus
nice!
Old May 19, 2012 | 12:11 AM
powersauto's Avatar
powersauto
thanks.... i can't wait to get tis car done
Old May 19, 2012 | 07:54 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Looks like alot of fun happening there Agree with the nice weld comments
Old May 19, 2012 | 08:54 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
holy moly! do you have a robot-welding machine in your own garage or what?
Old May 19, 2012 | 12:49 PM
Crepitus's Avatar
Crepitus
Powersauto knows how to walk a cup! pipe welder buy any chance?
Old May 19, 2012 | 06:42 PM
powersauto's Avatar
powersauto
Yes sir local 636 in Detroit
To c3 road race build
Old May 19, 2012 | 08:13 PM
TheSkunkWorks
Dang, that is some beautiful welding.
Assume you'll tie the cage down to the frame just ahead of the kickups, and while you're already going to this much effort I'd definitely run it forward up to the front suspension.
Old May 19, 2012 | 09:47 PM
Crepitus's Avatar
Crepitus
Right on brother! L 32 myself
Old May 20, 2012 | 12:39 PM
Neptune75's Avatar
Neptune75
local 370. Flint. Are you working this summer? ill be looking for welders in detroit Just got the Lake Orion job.. i Run the fab shop. Rich.
