Removing horn button on 78?
Old May 19, 2012 | 07:07 PM
78anniversary's Avatar
78anniversary
Default Removing horn button on 78?
Can someone tell me how to remove the horn button on my 78?
Old May 19, 2012 | 07:12 PM
...Roger...'s Avatar
...Roger...
The button itself you are supposed to be able to just pull it off,Ive had to pry them off on occasion.
Old May 19, 2012 | 07:38 PM
Shark Racer's Avatar
Shark Racer
I discovered the hard way, it's better to stick a flat blade screwdriver in there as far as it will go and give it a twist. You can pull the retaining ring straight off the emblem if the upper horn contact is tight.
Of course, I pulled mine off at least 10 times before I ripped the horn cap off of the retaining ring.
You have to angle the blade up a little bit to get it above the telescoping ring, then gently push it in as far as it'll go and give it a twist. I used a 3/8" blade screwdriver.
To Removing horn button on 78?
