72 Colors and Tire Size
[Modified by pats406nitrovette, 8:41 PM 5/22/2002]
[Modified by pats406nitrovette, 8:44 PM 5/22/2002]
Good Luck with it!!
AC
As for color....why not look aroud when you're driving and see what catches your eye. You just might see a 90's something Dodge Ram truck or 70's something Porsche that has the color you like. Looking a chips in a paint store doesn't always yield the results you are looking for. It's better to actually see the color on the road. Once you find the color, find the year and make of vehicle then you can cross reference the big book the paint store uses and you'll have the exact color you want and the exact color you have already seen.
Thanks L.A, that's probably what I'll have to do, look at some colors up close. The paint chip for Mille Miglia looks pretty flat on paper. The GM truck colors are kind of nice, I just wasn't sure if people would think I was crazy. :crazy:
No clearance/rubbing/wandering issues at all.
Select your year, then Chevrolet and click the search. The 1972 Corvette colors are on the bottom on the chart. Admittedly, you can't get the full effect on a computer screen.
Base/clear is not a different paint. It is a different paint system and drives your methods. You can paint the car with any available paint type and clear coat it or not. No doubt that a clear coat is more survivable in every day driving but you can paint in polyurethane and not clear coat or you could paint it in lacquer and use a lacquer or poly clear coat if you so choose.
Factory tire size was an F70x15 which lays between a 215-70x15 and a 225-70x15. Either size will work just fine. I'm using the 225s.
[Modified by gdh, 4:26 PM 5/23/2002]
The bottom line is, great car...and its yours...make it the way you want it. :cheers:
RPO Exterior Interior Soft Top Production
912 Sunfire Yellow BK-S BK/W 1,543
924 Pewter Silver B-BK-R-S BK/W 1,372
945 Bryar Blue BK BK/W 1,617
946 Elkhart Green BK-S BK/W 4,200
972 Classic White B-BK-R-S BK/W 2,763
973 Mille Miglia Red B-R-S BK/W 2,478
979 Targa Blue B-BK BK/W 3,189
987 Ontario Orange BK-S BK/W 4,891
988 Steel Cities Gray BK-R-S BK/W 2,346
989 War Bonnet Yellow BK-S BK/W 2,550
Abbreviations: B=Blue, BK=Black, L=Leather, R=Red, S=Saddle, V=Vinyl, W=White
