I give up
Old May 22, 2012 | 07:29 PM
tomnewell's Avatar
tomnewell
Default I give up
I changed the blower motor, heater resistance, the relay for the a/c, the fan control and still the blower won't work. what else could it be...it's a 79 .
Old May 22, 2012 | 07:37 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
I'll assume you checked the fuse...
Since the blower doesn't operate at all, the next thing to check is that you have good ground to the motor (Should be the first thing you check before changing the motor).
Old May 22, 2012 | 07:53 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Have you tested for power before you replaced anything? Do you have any speeds?
The brown wire carries power to the a/c switch which powers up the blower switch on the yellow wire.... Pull off the console side trim panels and start testing the wires.. You'll find your problem.
Old May 22, 2012 | 09:10 PM
wnmech's Avatar
wnmech
Have you checked the ground wire? Also try connecting up an extra known good ground point for troubleshooting. Also make a jumper wire and find a 12 volt source and apply the jumper wire directly to the connector to the blower motor and see if it runs.
Old May 22, 2012 | 09:24 PM
tomnewell's Avatar
tomnewell
thanks for the help, found it
Old May 22, 2012 | 09:27 PM
oldalaskaman's Avatar
oldalaskaman
you could post what you found, I dont need it but you got help and it might help someone else
Old May 22, 2012 | 10:04 PM
tomnewell's Avatar
tomnewell
what I found was a poor ground at the blower motor, what a poor ground can cause
Old May 22, 2012 | 10:11 PM
oldalaskaman
many thanks, bob
To I give up
