Water pump advice
Old May 22, 2012 | 10:31 PM
RedZR's Avatar
RedZR
Default Water pump advice
I need some advice on a project related to my 78 Pace Car.
I am getting the car ready for summer and am in the process of replacing the coolant hoses, cleaning the radiator and painting some areas of the frame (like the front crossmember). I also want to repace the fuel pump (the one thats on it is the original one) it does not leak but I do not want it to leave me stranded due to age related failure. I plan to take a few longer trips this year.
The previous owner replaced the radiator and water pump 10 or 11 years ago (car has 26k miles on it) and the pump has 5k miles on it- max. The bearings seem tight, no leaks and the car runs pretty cool.
As I replace the hoses I have been thinking about changing the water pump as a preventative measure, especially since I have everything apart now. However, the though of fixing something that is not broken keeps ringing in my head.
What do you guys think? Should I swap the pump?
Thanks,
Dan
Old May 22, 2012 | 11:42 PM
oldalaskaman's Avatar
oldalaskaman
no
Old May 23, 2012 | 12:28 AM
TimAT's Avatar
TimAT
Classic example of "If it ain't broke, don't fix it".
Water pumps seldom fail unexpectedly. They leak, drip, throw coolant everywhere, but rarely die like fuel pumps can and do.
The odds of getting a new water pump with a problem are way better than you running one that has 5k on it.
Old May 23, 2012 | 10:51 AM
TWINRAY's Avatar
TWINRAY
I would regard the 5K miles on the pump as "shakedown" miles - ready for another 95.
Additionally to make you feel better, I took an under 5K mileage pump off my oem motor, painted it and put it on my new ZZ4 replacement engine.
Old May 23, 2012 | 10:56 AM
Marlin's Avatar
Marlin
I have seen ones new from box leak in less than 5k. So if you have one that is tight and not leaking why take the chance of going from a working one to one that may have some doubt to it?
Old May 23, 2012 | 01:14 PM
scottyp99's Avatar
scottyp99
I concur. Water pumps don't usually just stop working, all of a sudden, like a hose or a belt can. They gradually wear out, giving you plenty of warning, if you are paying attention. Just keep an eye on it for a few days, a couple times a year, like in the spring, after it wakes up from its long winter nap, and again, before bedtime in the fall.
Keep the shiny side up!
Scott
Old May 24, 2012 | 11:47 AM
71rdster's Avatar
71rdster
If you are into a little bling under the hood,you could replace it with a polished aluminum unit or a chrome one "while you're at it", but if this is a daily driver, leave it alone.
To Water pump advice
